eg
http://forums.vwvortex.com/showthrea...-relay-problem
also
http://www.msextra.com/forums/viewtopic.php?f=4&t=47813
double check the installed firmware.. and the version of firmware in tunerstudio used to send data to the MS..
if it's burning tables in wrong place of memory, it will go whacky.. but weird it starts at all
unless it is just running on the priming pulse?
another issue could be the crystal gone bad (as per last link)
msq is the data file saved to the MS...
actually.. whatever file you save in tunerstudio is what I wanna see, to make sure you have config ok in software...
but if that doesn7t match the MS firmware version, that doesn7t help anyway
running MS2 hardware? MS1?
