Cheers Peter, i've tacked that onto the end of the listing.
Sam
Sam,Originally Posted by CrUZida
I just picked up a set of the Mackay Engine Mounts. Coventry's quoted me $80 each and weren't really that interested in getting them. I ended up getting them from Repco (after a 2 week wait) for $110 for the pair!!
So try Repco first for these.
Regards
Peter
Sam
MA61 Part Numbers, Upgrades and General Infomation <--- Clicky Clicky
Sam,
some more info for W58 & W57 boxes:
11 tooth Speedo Drive gear (will mesh with 31,32 & 33 tooth driven gear) part 33481-22020, $57.15 ex Japan (2 - 3 weeks)
32 tooth Speedo Driven gear (this is the plastic one - will only mesh with 11 tooth drive gear) part 33403-19255, $52.95, stock in Aus
The above combo (32/11) is perfect for a 3.73 diff ratio & stock rolling radius tyres (ie 195/70 R14 or 225/60 R14)
Regards
Peter
Holy crap those are expensive prices! I hope that was with a discount.
Thanks for the info too, i'll try and weave it into it.
Not too bad when you compare it with the price of an external mechanical box to correct the speedo (quoted $250 - $300). I've also been told the external boxes aren't all that well made any more.Originally Posted by Negative Boost
Regards
Peter
Drive belts, plugs and leads for the ole 5ME with pricing from Repco:
A/C - 13A0990 - $15.99
Alt - 7PK0920 - $32.79
P/S - 13A1420 - $19.99 <----- (Actually from a volvo. They will try and sell you 13A1205 but it's the WRONG belt!)
NGK Plugs - BPR6EY - $26.34 (for 6)
Top Gun Leads - TG6032 - $64.99
Cheers big ears, that reminds me to put up peters stuff too! oops!
Anyone have the part numbers for the heater hoses? (I think there are 3 in total)
If no one does, I'll get them eventually.
Edit, im gunna shutup...
Saves me telling you to![]()
Lols....
Taken from the 2004 EPC
Thems the chickens.
I may as well replace all 4.
Thanking you.
hey guys,
ma61turbo siad that part numbers for Shifter Bushes are:
Rush Shift RN7808(Bush on bottom of W58 shifter) 33548-31010 $8.64 *not RN7807 as in OP
Seat MTM LVRLN46811(W58 shifter lower seat bush) 33505-35020 $19.50
is this from toyota?
a dude from toyota told me i need to buy the whole retainer for like $200.
.. i obviously ran away.
thanks for your help... im new to bushes...
Yup, those them ones at Toyota. Ask for trade price too if they're friendly. I got my last pair of bushes cheaper than that.
The $200 one is probably the bush in the selector fork which you dont have to worry about here in Aus. However in the US, aparently its common for this bush to wear out and fall to bits.
It's been a long time since I've seen a 5M in an MA61, reckon these hoses would work for the 7M as well? Cant remember what hoses I used the first timeOriginally Posted by Negative Boost
