From what I have seen the 7M GE (grey plug ECU Type) Coil/Igniter is the same.
Hey Guys im a newbie here....im also from Jamaica...got a questions for all the !GGTE guys...
I have a GX81 Cressida, with a 1G-FE...swapping to a 1GGTE...the problem lies that i got the AFM, ECU with the engine but as i realize by going through your threads the Coil/Igniter Assy i have gotten with the engine is incorrect....wondering if there is any other Assy that can be used or converted to use with the Engine...BTW is a Gen 3 Engine (Gray Plugs, Lime Green Injectors)
Plz Help![]()
You may have to rewire the plug but the 7m igniter should work fine.
GA23(never finished-now with cracked block) JZX83 (Tyre eater) 3sgte AE86. by now i should know better.
