Results 1 to 5 of 5
Thread: Torsten into Hilux.
    Low rep 1st year Apprentice
    Nov 2013
    queensland
    Default Torsten into Hilux.
    I have read a lot around the Torsen being put into the Hilux housing but with maching required, my questions are:
    Will a JZA70 Torsen fit a g series housing?
    Will a JZA80. Torsen fit. G series housing?
    Is there somewhere in Brisbane some diff joint or person has done this mod?
    Default Re: Torsten into Hilux.
    I have done it a few times. JZA70 torsen will fit using a spacer .JZA80 will not fit
    Jealousy is a curse
    Nov 2011
    I may be a month late but for others info the easiest way to fit a Torsen LSD into your Hilux (or Hilux rear axle that you've fitted to whatever) is a trip to the wreckers and get the rear diff from a 2008 on KUN26 Hilux. They have a Torsen LSD as stock and if memory serves correct the ratio is 3.65:1
    His. 2005 GRJ120 Prado VX
    Hers. 1995 KZN130 Surf (soon to be replaced by a Rav4)
    1981 LN40 Hilux Trayback ute. Now an RN40 with Surf interior
    1992 Factory Widebody 2door Surf 1UZ-FE V8 Auto, now for sale
    May 2007
    3.55 ratio
    Nov 2013
    queensland
    They are actually 3.58 but I dont know of anyone who has used it witht he Torsen in the Gseries housing, the pinion bearing is a different ID.
  1. Replies: 1
    Last Post: 06-08-2011, 12:44 PM
  2. information on 1GGTE into RA23, hilux,crown,carona pug brake upgrade, hilux diff.
    By celica77 in forum Engine & Driveline Conversions
    Last Post: 15-05-2007, 11:14 AM
