I've been quoted around the $1100-1200 mark for a machine shop to do the following. My aim is an OEM quality rebuild. Price will vary so take it as a ballpark only.
block acid tub and crack test (around $200 or so and then have the option not to go any further if things don't look right)
decking the block and rehone cylinder chambers
supply new piston rings to suit rehone specifications (this is if I can still use my stock pistons, otherwise supply 0.5mm oversize)
check crank straightness and linish
supply new mains and rod bearings to suit
remove valve spring retainers, valves and springs, check everything
head acid tub and crack/warp test (again similar to above, can decide to stop here if need be)
head skim and install stem seals to be supplied by me (OEM toyota)
All disassembly/reassembly to me done myself, which I'll be having someone with engine reassembly lend a hand to ensure everything looks fine.
I am also going to opt for a rotating mass balance which adds another $200 on top.
You have more experience than me; prior I have done exhaust swaps, intake removal/vacuum hose diagnosing, replacing CV boots, cooling system parts replacement etc. And thus far I've performed an engine teardown without too much difficulty, so as long as you are patient and have an eye for detail, you shouldn't find a 4AG rebuild too hard.
<this is the part that is up for discussion, please do not take my word as gospel as mentioned I've never rebuilt an engine myself>
I've found the following are a good starting guide for consideration:
- You are looking at increasing HP but running stock engine management, so any major changes are not going to reflect well. I'd try to keep CR close to factory, maybe no more than 0.3 increase? Someone can add a little more here. On my GZE I wouldn't go more than 8.5 on a stock 8.0 CR. Easiest way around this is just to run an engine and ECU with better CR, eg. a 8.9 CR AE101 GZE engine and ECU.
- Any changes that will affect AFR will not go down very well on stock engine management. You'll find yourself running lean very quickly and an engine that might not last more than 10-20,000kms due to detonation.
- Increasing bore unnecesarily will shorten your blocks lifetime. If you blow rings again and need another rehone you'll be a lot closer to the limit of what the block can reliably take. If you have a 3-rib 4AG then this might be even less due to less block reinforcement.
- Running up to 256 cams sounds fine for stock management, but just remember the above advice. It's not a hard and fast rule that those cams will work despite other modifications also done to the engine.
If you pull off the head and find your bores look fine, is there much reason to touch the short block straight away? I would rather look into getting the head port matched and possibly 5 angle valve job. Get the head breathing better and you'll find a nice increase in power over factory, which would be even more beneficial for a cam upgrade. You can then go even further with more aggressive cams and aftermarket ECU, and just keep driving it until you finally do need a bottom end refresh.
If you have to get the bottom end done, definitely get it all balanced, but then it's up to you how far you want to take it, budget increases quickly when you start thinking about replacement pistons and rods etc.
