Results 1 to 15 of 20
Thread: Trumpet size for 20v
    Aug 2013
    Auckland
    Default Trumpet size for 20v
    After reading hundreds of forum topics about the length of the trumpets i should run i think its better to just ask if anyone is running a 20v on trumpets and what size are they using. I am after high rpm power upwards of 4,400rpm.
    thanks
    Default Re: Trumpet size for 20v
    100 or 110mm. Multiple customers report and mid and top end gain over 70mm stacks.
    loves hi RPMS Backyard Mechanic
    as above.
    if cant fit those, 50mm seems to be a decent compromise at some sort of mid range while having plenty above 4500rpm.
    N/A for life...
    Aug 2013
    Auckland
    Thanks guys. The Silvertop is just begging for trumpets.
    Looking at some 100mm ones, seems an good option.
    kiwi, what model car is it going in?
    I can supply velocity stacks if needed
    Aug 2013
    Auckland
    Quote Originally Posted by Sam_Q View Post
    Its a Silvertop 20v in a 1984 FXGT hatch. Would prefer them to make power above about 4,000rpm as the VVT operates on the TPS and not at a set-rpm range.
    The trumpets will be mounted in a sealed box that will fit secure against the bonnet and have a vent feeding it with cold air.
    looks like you have lots of room, I suggest the 110mm length
    Aug 2013
    Auckland
    Why would you recommend 110mm? How do the lengths work?
    Junior Member Grease Monkey rick q's Avatar
    FWIW, I started with parallel sided ram tubes 115 long, but for packaging reasons had to change to 75mm tapered, and was pleasantly surprised to pick up 3-4hp as a result.
    I think there are many many variables in this, and that sometimes the maths [which suggested 115mm] sometimes throws its hand in the air!!!
    Cheers ..... Rick Jones
    Fraser Clubman
    Aug 2013
    Auckland
    Yeah somepeople swear by short tubes and others by long ones.
    The engine has had the following work done:
    Blacktop Intake Cam
    7afe headgasket
    Blacktop ECU
    2.5inch free flow exhaust no cat
    Basically i need it to make peak HP as it will be a hillclmibing/rally car and it wil spend most of its life in the 4,000rpm plus side of the rev guage.
    Quote Originally Posted by kiwi View Post
    That's because different lengths have different effects - long tubes tend to improve low- and mid-range torque, short tubes top-end power. The problem is that since most people tend to quote peak power figures, a set of long trumpets might look like completely ineffective mods on paper since peak power doesn't change, but the mid-range benefits are massive. I know of some 2ZZ guys with aftermarket cams and ECUs where the peak power figure has barely moved but there are ~30% gains in the mid-range, completely changing the nature of the engine (no longer need to wring every single rpm out of it to ensure you land back in lift when you change gears, for instance)
    Jul 2009
    I've been making proto types with my 3D printer to see what lengths provide the best results for my AW11 with it's 20V ST.
    I have sold many stacks from a radii in flat plates to 150mm. Now I normally don't like making a judgement from feedback alone however I had quite a few reports now to get a rough idea. I am sure it would happen for some however I didn't have a single customer report of losing power in the top end. I had a back to back dyno run organised with the head of a Clubbies group but it was cancelled, a pity. I do have a dyno run of a BEAMS engine with 70mm VS 110 that's rather interesting but a very different engine.
    Of note a friendly customer of mine is using 100mm small bellmouth stacks on his high power 20v, it does displace 1.8L progressively till high revs with a 83x83 bore/stroke which likely changes things quite a bit. I should ask him why he chose that length.
    knightrous: nice work, going to make four of each and do some test runs?
    Jul 2009
    Yes, that is the plan. Currently I have 80mm and 120mm designed units and will do a few in between designs, but mainly I want to test to see if the ABS plastic will survive the harsh environment of an automotive. If it does, these are super cheap to produce, using only $6.00 of ABS filament and 15hrs to print per 120mm trumpet.
    Tallahassee, FL USofA
    Cut yours & use hose&clamps to find what you like best.
    Dyno or off road or road race or hydroplane or rock crawler or bling or just a fun DD?
    X2
  1. ITB Trumpet Filters
    By Bazooka in forum Tech and Conversions
    Last Post: 11-06-2013, 08:17 PM
  2. 20V Trumpet setup
    By GEMTA22 in forum Tech and Conversions
    Last Post: 01-07-2010, 03:38 PM
  3. trumpet size for 20v?
    By Wanabe_Garage in forum Tech and Conversions
    Last Post: 24-03-2006, 03:37 PM
