Results 1 to 5 of 5
Thread: Changing CAS gasket and inner seal - GZE
    Default Changing CAS gasket and inner seal - GZE
    Hello,
    Wondering if anyone can give me a bit of a walk thru in changing the CAS to block gasket and the inner seal of the CAS ( Map 4agze ).
    Basically does the engine need to be TDC to remove CAS and so on? Anyhelp much appreciated.
    Tyrone.
    south australia
    Default Re: Changing CAS gasket and inner seal - GZE
    this may be of some help.....
    http://www.toymods.net/forums/showthread.php?t=5047
    you should have the engine on TDC as well. it will make it alot easier to get it back together.....
    Junior Member Grease Monkey craigy's Avatar
    -set crank to TDC
    -mark with a paint pen, the position of the CAS (timing point)
    -remove CAS
    -remove old o-ring and replace (use vaseline to lube o-ring)
    -line up dimple on the shaft (closest to gear) and the strike on the CAS body
    (assuming they are the same as a bigport distributor)
    -reinsert CAS and tighten bolts
    DONE!
    hope this helps
    Craigy
    Cheer's Craigy - I'll get to work on it. + Rep
    Changine the inner seal (and bearing while you're at it) is a little bit harder, it requires you to drill out the rivet/stake (?) that holds the gear on the end of the shaft, and pulling out the shaft. The bearing & seal pop out & are replaced like any other bearing & seal (not that hard) then put it all back together, & the fun bit is finding something to replace the bit you drilled out.
    I was able to get my hands on some solid Al rivets of varying size & length, one of which was a perfect fit.
    Install CAS/dizzy back into head, & wait about 2-3 weeks before the bastard starts leaking again!!!
