Thats 3sge beams yeah?Originally Posted by The Last Streetfighter
anyone having 1JZ-GE VVT-i?
Which vehicle?Originally Posted by 1JZ-GE
Jealousy is a curse
I am not sure what this cut came out from but I believe it may be from Toyota Mark II. The motor and ECM are finally with me and attached here.
I hope these can help identify the motor and get us the pinout.![]()
Looks like a 96-98 JZX100 and I cant help
Jealousy is a curse
I was looking for the pinouts for my Australian delivered 3RZ-FE . Eventually found them printed on the board inside the ECU.
Jealousy is a curse
http://gallery2.plebeians.net/v/cars...ossibleJSZ155/
Whole bunch of 2JZGE wiring diagrams there. Possibly for a JZS155. Will confirm in the coming days
Thought I'd share these with you guys. These files took many hours to compile, hopefully they help someone out!
I used the usual Toyota wire colour and plug name nomenclature...
Ed was kind enough to host the files on his forum here:
http://www.v-eight.com/tech_forum/vi...hp?f=59&t=1254
Or, if you aren't a member try downloading from rapidshare (it's fairly ghey though).
JZA80 Series 1 2JZ-GE Engine Harness to Chassis Harness plug pin-outs.
http://rapidshare.com/files/26873535...S1_Pin-out.pdf
UZZ31 Series 1 1UZ-FE Engine Harness to Chassis Harness plug pin-outs.
http://rapidshare.com/files/26873536...er_Pin-out.pdf
UZZ31 1UZ-FE to JZA80 Chassis Harness pin-outs (including Hydro Fan ECU).
http://rapidshare.com/files/26873535...ng_Harness.pdf
UZZ31 to JZA80 Cruise Control ECU pin-outs.
http://rapidshare.com/files/26873493...ontrol_ECU.pdf
Let me know if you have any questions!
Do you have a diagram for a UCF11 1UZ-FE?
They are available on Lextreme mate.
http://www.lextreme.com/forums/showt...ighlight=ucf11
Nah i need one for a '92 ucf11 ecu plugs like this http://img99.imageshack.us/img99/9253/1003520.jpg Ive opened it up and theres no writing on the pcb for pinouts
There's also a few at this address on lextreme - http://www.lextreme.com/misc.htm
2jz-ge soarer ecu pin out and wiring diagram needed, mainly ecu pin outs
really stuck here guys does anyone have anything? Need to get 2jzge running in a corona so need the fuel trigger wire, BATT IGN and earth asap, also anything else i might have forgotten
