Checked ToyoDIY?
I'm swapping out the C50 out of my AE82 race car for a C56 but the throw out bearing and clutch fork is larger than the one in the C50 and they need replacing. I always thought all C series gearbox's had the same thrust bearing but obviously not.
Does anyone know the part number I need to order for the C56 throw out bearing??
Cheers, Justin.
1970 2M MS55 Crown - Weekend Cruiser.
1970 2R RT40 Corona - Cruising Grandpa Style
1986 20V 4AGE AE82 Corolla - The Brown Racecar.
1988 4AGE AW11 MR2 - Sold but not forgotten
1992 1MZFE SW20 MR2 - Sold Supercharged V6 Monster.
Checked ToyoDIY?
The bearing that was out of my small port c56 is by Nachi NP-50SCRN3IP-4. It has a plastic/rubber lining on the inside diameter where it slides back and forth over the input shaft.
http://www.vxb.com/page/bearings/PROD/Kit12539
You can also find it at the Exedy website
AE92/AE93 > 1587cc> Part number BRG2248:
http://www.exedy.com.au/clutch-finder
I wouldn't get the NSK 50TKA3305R as it is a shorter bearing and if installed you may need to adjust the clutch pedal rod to compensate for the longer range in movement. I had to do this and also use a longer slave cylinder rod, made one from bolt.
cheers.
deepdishfactory
