Results 1 to 3 of 3
Thread: 7MGE into MX32 / MX36 Cressida
    Jun 2011
    Default 7MGE into MX32 / MX36 Cressida
    Hey guys, just wondering if anyone has any information on doing a 7MGE/TE swap into a MX36 Cressida? Had a look around the net and there isn't much information about the swap. Any help would be great.
    Mar 2012
    Default Re: 7MGE into MX32 / MX36 Cressida
    found a thread from google on celicasupra asking about a 4m to a 7me (he meant 7mge) swap, good read.
    Motor should mount in the same spot using the same holes, gearboxes should bolt up but the common consensus from 5 minutes on google is the auto (if it is) wont like life and the manual w50 would be better swapped for something else.
    If its a 4m (not a 4me) then you'll have to put a efi pump in the tank and maybe run a return line. Basic carb to efi swap stuff.
    If its efi then its just get the 2 wiring looms and wiring diagrams.
    Just at a guess it shouldn't be the hardest conversion in the world.
    Jun 2011
    Thanks for the help, just had a read of that thread. Doesn't look hard at all.
