Results 1 to 14 of 14
Thread: Brake Booster Questions
    Sep 2011
    Default Brake Booster Questions
    Hey guys,
    I am sourcing parts for my brakes/coilover install.
    Just wondering if there is much a difference between leaving it stock or upgrading it to the Mitsubishi Pajero MC or a 2003-2006 Camry MC.
    I can get the sizing for you too if that helps. All options are direct bolt in just not sure which I need if I were to do a hilux 4 pot or corona 2 pot upgrade.
    Tony
    Feb 2012
    Wa
    Default Re: Brake Booster Questions
    Talking about master cylinder?
    I don't think u would get a Camry booster in to the celica, the factory one should be good, just rekit it and fit a one way valve, with the Camry master cylinder
    Sep 2011
    Yeah I meant the master cylinder, my bad.
    How would i go about rekiting it and fitting the one way valve?
    Administrator Domestic Engineer mynameisrodney's Avatar
    I've got the a camry MC bolted to the stock booster in my 22. Can't remember what year camry it was though. I'll see if I have it written down.
    Pics
    Feb 2012
    Wa
    That is if its fucked that it,
    Take it to a brake shop that does this Type of work, they will fit a new rubber diaphragm to it and clean it out, they will be able to supply a valve to, you just fit that in the line, other wise a backfire through the intake will blow the diaphragm
    If you look at the. 2nd and third pic you can see it, follow the line to the intake
    This post is full of the good stuff
    http://www.toymods.org.au/forums/tec...k-diaf%5D.html
    Sep 2011
    Quote Originally Posted by mynameisrodney View Post
    Pics
    Thanks for the photos. That is one very clean engine bay. Nice work.
    Is there any reason why you chose the camry one over the pajero?
    Sep 2011
    Quote Originally Posted by Dan_k36 View Post
    That is where i was getting the information from, I'm trying to work out which is better the camry or the pajero.
    Apr 2007
    Actually the one way valve is there, so if the motor stalls you still have boosted brakes for a couple of applications also if you are hard on the throttle & just come off as you hit the brakes again you will still have vacuum in the booster etc ...
    Quote Originally Posted by Tonyger View Post
    Cheers. If there was a reason, I have long since forgotten it. May have been simple brand loyalty.
    Chris
    In answer to the original question - you will definitely need to upgrade your master cylinder if you are going to be running the bigger calipers
    You will end up with a mushy pedal other wise, that no amount of bleeding will fix.
    Now - RA23-WRX
    Jan 2011
    Sorry, misread as asking about ra23, not 22.
    Tasmania
    A70 Cyl wont bolt on as its 4 bolt not 2.
    Cheers Brett.
    Sep 2011
    I ended up picking up a pajero master cylinder and I've pulled out my brake booster for a quick clean and a lick of paint.
