Results 1 to 8 of 8
Thread: 18RG no spark
    nice datsun Backyard Mechanic TRD184's Avatar
    Jan 2009
    New South Wales
    Default 18RG no spark
    hey toymods, wondering if someone can help me, ive got an 18rg with the 22r electronic dizzy and a bosch 4 pin module. ive got spark from the coil, but nothing out of the dizzy, ive tried 3 rotor buttons, 2 caps, different leads, im at a loss at this poont and i need the car to get to work monday :/ hope someone has an idea thanks
    my RA23 http://www.toymods.org.au/forums/showthread.php?t=57060&page=2"]
    It's 106 miles to Chicago, we got a full tanks of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
    - Hit it.
    Sydney N.S.W
    Default Re: 18RG no spark
    is the something that just occurred or you just converted it?
    Jan 2009
    New South Wales
    only recently occured, got it sorted,spark was blue, but apparently not strong enough. bent the tabs on the cap in and it started. BUT. now its running, its on 3cyl below 2000rpm, high pitched rythmic squeak from top of the motor, changes with rpm. cyl 4 is the dead one, sneezes fairly often from that carby too. thinking vacuum leak, ive a socket set and thats it. anyone had this before? ive seen v8s with a single plane manifold squal like a kettle due to leaks, but i imagine since this is a runner per cylinde, id expect the pulsating squeak like ive got. i dont know what else would cause such a noise
    - Hit it.
    Junior Member Grease Monkey Rens's Avatar
    Nov 2010
    Valve train damage maybe ?
    Have you pulled number 4 plug out and checked spark ?
    Aug 2013
    Quebec, Canada
    Spray carb cleaner, brake cleaner, anything in aerosol around the whole intake tract of #4, mainly around the gasket area. If problem goes away momentarily and then comes back, you've got a vacuum leak... you can probably pin point it by being less liberal on the cleaner working your way toward the area where "it solves the problem". If that don't cure it, spray some down the #4 carb an see if it help. If yeah then that carb is not fueling your engine properly.
    Otherwise you can scratch that off your list and move toward the head :S
    Hope that can help you.
    KE20 1974 <- Sold -> Thread
    AE95 1990 <- 4A-GZE daily driven wagon...
    Apr 2007
    Quote Originally Posted by TRD184 View Post
    You said you bent the tabs in on the cap, i'm assuming you meant inside the distributor cap, if that's the case not a good move, it will / can cause hairline cracks inside the cap & then tracking / arcing / missing too the best way is to sit the very tip of the rotor button ( the brass section only ) on say the edge of a vice & then hit it with a hammer to flatten out / lengthen the very end of the rotor button, works well ... Is there spark on No 4 cylinder now & did it miss before too ?? Check the noise is not coming from the dist cap after you bent the tabs in, probably not but worth listening too, sounds like as you said a possible vacuum leak ?? spray some crc or such around the carby body & manifold sandwich area & see what happens, if its leaking air the revs will increase & start running on that cylinder ..
    As has been mentioned if none of the above changes anything I would be carrying out a comp test & going from there ..
    Sydney N.S.W
    I did have a spark problem years ago.
    ended up being a bent dizzy shaft.
    Once i changed it, all was fine.
    I still have the dizzy as a momento. lol
    Jan 2009
    New South Wales
    found! i didnt have any carby cleaner or anything around, literally just some sockets and 3 screwdrivers. but as i was going around checking all the manifold bolts, it sneezed out the carby and i felt it on my hand! so, voloius, replaced rear carbs gasket, fixed, that where it was! relieved too as i was starting to get worried. thanks for all the help fellas and that was a good idea lexmaz i did as you said and used my spare cap. number 4 had spark once i got it running but the cylinder was dead, the new gasket has cured that though
    - Hit it.
  1. 18rg ignition spark dodgy
    By DaveSpec in forum Tech and Conversions
    Last Post: 03-04-2012, 06:11 PM
  2. Using 7m ecu for spark only -no AFM
    By andrew_mx83 in forum Tech and Conversions
    Last Post: 14-05-2010, 06:29 PM
