Results 1 to 6 of 6
Thread: Sumitomo caliper rebuild - rt132 corona
    Jul 2012
    Default Sumitomo caliper rebuild - rt132 corona
    Hi all,
    Just picked up some front sumitomo calipers out of an 1981 rt132 corona, intending to use these in my xt130. Seals and pistons look as though they could use replacement..wondering if anyone has done a rebuild on any sumitomo calipers before? Tips and info appreciated. Cheers
    Default Re: Sumitomo caliper rebuild - rt132 corona
    Get them rebuilt by a brake shop.
    It wont cost you much more than a rebuild kit, and then you can be sure its done right.
    highly underrated Backyard Mechanic
    Feb 2010
    yeah id agree unless you have the tools to do it (air compressor and a special tool I had to make) you'll struggle getting the pistons out
    RT104 with 4AGTE
    Some assembly required
    Jul 2012
    Thanks, will look into that and see what the costs are. 2004lowlux, what is the special tool you had to make as I already have an air compressor?
    Feb 2010
    I found a fitting that screwed into the caliper where the brake line went in and that fitting also screwed onto the airline, peeled the dust boots back and sprayed in some wd40 then wrapped the whole thing tight in a rag and turned the air on.
    once the first piston shot out I found a small can big enough to fit over the piston but half the width of the caliper gap and had an adjustable rubber backed plate that sealed the hole from the missing piston and allowed the other piston to get forced out.
    finding a plate like that will be hard I just happened to have one here.
    RT104 with 4AGTE
    Jul 2012
    Cheers. Will look into some pricing to get rebuilt professionally by a brake shop and see how things go from there. Sounds like that will be the most practical option
  1. sumitomo twin pot caliper question.
    By ToyTA22 in forum Tech and Conversions
    Last Post: 12-03-2013, 02:39 PM
  2. Corona Sumitomo brakes and struts??
    By Snyper in forum Tech and Conversions
    Last Post: 09-09-2006, 07:17 PM
