You say there is very little pedal movement, does the clutch pedal not go to the floor ?? does it feel like its hitting a brick wall when you say the travel is short ?? Is there a lot of slack in the pedal before it feels like its doing something, you could have air in the system if there is a lot of slack feel in the pedal .. Need more info ..
Depending on how your clutch slave cylinder is set up, some slave cylinder pistons bottom out in the housing & have an adjustable pushrod so changing the rod can make a difference to how the clutch works, other's the slave Piston just stop's anywhere down the bore of the cylinder & so putting a longer rod in is not going to do anything ..
