Results 1 to 4 of 4
Thread: RA40 18rc to 2t-g conversion
    Sep 2011
    victoria
    Default RA40 18rc to 2t-g conversion
    Hi folks.
    I have just scored a 2t-geu with solex carbs which I am looking to sling in my RA40 . I know there can't be too much in it as they were produced with this engine fitted, but there are some differences I have noticed. If you can help with any pitfalls or things I need to modify and buy to make it a hassle free swap it would be greatly appreciated . Have a W 50 box and a 18rc fitted. Got 95% of the bits for the engine . No trottle linkage , extractors , choke? Fuel pump, air box. Cheers
    Aug 2009
    Default Re: RA40 18rc to 2t-g conversion
    TA40 with 2TG used an alloy split case T50 gearbox and the 18r bellhousing will not fit the 2TG.
    If the 2TG you have has a front sump you will need the TA40 cross member which is the same as TA23, other than that, minimal changes required.
    Rgds, Willofan
    Sep 2011
    victoria
    Cheers Willowfan, thanks for the info, my next question , where the feck to get a ta 40 crossmember and bellhousing to suit...lol , thanks ahead of time..
    you can use a ta23 x member as willofan said. just go tot he wreckers and grab a gearbox from a t18 or ta22/ta23
  1. RA40 1UZ-FE Conversion
    By slopshua in forum Tech and Conversions
    Last Post: 05-05-2010, 05:28 PM
