Results 1 to 5 of 5
Thread: Changing diff centre
    Nov 2012
    Nsw
    Default Changing diff centre
    Hi all.
    I was hoping I could get some help in regards to what needs to be done to chane my diff from a single spinner to an LSD?
    I own a ra23 celica with a 3tgte, and diff is from a 2wd hilux diff I believe.
    Is it just a matter of sourcing an LSD centre or would it be better to change the diff all together? Im not sure of the ratio, this would need to be established before selecting diff i gather?
    My knowledge in this area is fairly limited. Cheers in advance
    Default Re: Changing diff centre
    If the diff you are running is a hilux diff then it would be a G series diff which is very strong so you don't need to replace the diff all together. If it has not been shortened then it is likely a RN20/25 diff that is the right length for early celicas.
    To put a LSD into it you need to decide what type of LSD you are after and then go find LSD accordingly. You can either get a locker centre, a torsion centre or an clutch pack centre. There are differences between each so you will need to look into the pros and cons of each and decide what suits your driving style and pocket the best.
    A cheap option is a Tru Trac centre as for sale here for $350 (not my sale thread). This is a torsion LSD
    Once you have the LSD you will need to take the centre out of your current diff and take it down with the LSD to your local trusted diff shop and tell them to fit the LSD to the diff centre. To get the centre out of your current diff you will need to remove the axles partly (means taking brakes off etc) and undo the tailshaft. If this sounds like too much effort then just drive the car and the LSD to the diff guys and drop it all off and say make it work.
    The ratio of your diff does not affect whether or not you are installing a LSD. If you are happy with how it drives then don't change the diff ratio.
    Oct 2009
    Quote Originally Posted by Bruthrboodly View Post
    Find and buy a center that fits;
    Remove hubs and slide out the axles
    Remove the center, scrape off the old gasket and shit
    Install new center
    Slide in axles, install hubs and all that shit and away you go.
    Heaps of hilux LSD's out there, if you fiddle with the springs/shims they are half decent for what most people do.
    Junior Member Backyard Mechanic scottreichstein's Avatar
    Aug 2011
    cheapest option is to weld it that's what I have done
    if its a lux diff keep is as above said they are strong and lots of different ratios available I think a lsd centre should be round the $400 mark
    a lot cheaper than replacing the whole thing
    RIP st141 died doing what it loved http://www.facebook.com/media/set/?s...type=3&theater
    1ggte hilux massive 143rwkw http://www.toymods.org.au/forums/sho...724&highlight=
    corolla sportivo daily LIFT
    Nov 2012
    Nsw
    Awesome thanks heaps guys, I've got somewhere to start now. The LSD centre sounds like the best option for me with all things considered (price mainly lol). I appreciate the info
  1. Changing Diff Center in JZA80
    By Koffee-Black in forum Tech and Conversions
    Last Post: 28-07-2013, 03:25 PM
  2. Changing MX83 diff gear ratio?
    By nemesis86 in forum Tech and Conversions
    Last Post: 30-09-2010, 12:21 PM
  3. MX73 Diff Centre in RT142 F372 DIFF
    By Toyocorona in forum Tech and Conversions
    Last Post: 29-09-2009, 06:28 PM
  4. changing the gear ratio's in hilux diff.
    Last Post: 14-10-2006, 01:41 PM
