Results 1 to 4 of 4
Thread: Setting speedo for different diff ratio
    Aug 2009
    Default Setting speedo for different diff ratio
    I am changing my TA22 diff from a standard 4.1:1 to a 4.3:1 lsd with T50 gearbox. I don't know how to calculate speedo gears required in a TA22. Other manufacturers use 1000 cable revs per mile. If I knew where to find speedo calibration number I can calculate from there. Only number I can see on back of speedo is 057100 - 6050
    Also I am changing to a GT dash assembly so have access to back of speedo at the moment.
    Any help would be appreciated.
    Nov 2007
    Default Re: Setting speedo for different diff ratio
    On my RA28 or maybe it's my RA40? I remember seeing it printed on the face down the bottom.
    Glen
    RA28 (18RG)Members Ride
    RA40 (3TGTE)
    RA40 (18RC)
    SXA11R Rav4 Cruiser
    ACA33R Rav4 Cruiser
    Nov 2011
    change the diff then see how far speedo is out
    if its 10% to fast then on a 20 tooth gear u need to put a 22 tooth gear in the speedo drive
    I think that's right
    2sc Breaker!!!! Backyard Mechanic bmxer54's Avatar
    I'm not sure if i have this right or not but i'm hoping that the speedometer is calibrated to the wheel size and then the speedo drive is calibrated to the diff ratio
    I'm hoping it all works this way as I have thrown a hilux diff under my rt142 and my big problem is that it was built so long ago that I dont know the ratio.
    I have done some road testing (comparing gps speed to dash) and come to the conclusion that the speedo is 25% out. considering the stock diff was a 3.89 bw and it is now 25% out this brings me to the conclusion that my diff is a 4.86. Was 4.86 a hilux ratio? and is the first line of this post correct meaning all i need to do is find the speedo drive from something with a G142 as the diff code and a w5x box? Or is it as simple as dumbass has said and if say the current speedo drive is say 20 teeth the just get one with 25 teeth?
    Sorry for the massive post but there is alot rattling around in my head
    Peter
    My Rides:
    1x Brown St141 corona csx. powered by a gen 2 3sge, 1x RT142 turbo 1UZ, cd009 and G series, 1x Gj Sigma Scorpion injected and turbo'd, 1x KE30 2TG, w58 and F truetrac, 1x RT104 18RG, w58 and F truetrac
  1. What diff ratio is a 03 2wd 2.7 Hilux???
    By loluxsrus in forum Tech and Conversions
    Last Post: 11-03-2010, 07:30 PM
  2. what ratio diff should i use?
    By rn41leroy in forum Tech and Conversions
    Last Post: 09-11-2009, 02:14 PM
  3. A01B diff ratio??
    Last Post: 08-11-2006, 12:14 AM
  4. 4.5 ratio for t18 diff
    By Evan in forum Tech and Conversions
    Last Post: 01-02-2006, 12:50 PM
