Results 1 to 4 of 4
Thread: Cusco LSD transaxle oil
    Default Cusco LSD transaxle oil
    Hey all,
    so have a Cusco 2-way in a transaxle (FWD). Looking at their oils they list a 75W85 for them.
    Reckon it will be ok to run something like a Castrol LSD oil/Penrite or similar or should I stick with the manufacturers own?
    If i should stick with the cusco oils, anyone know of a dealer in Aus, preferably Melbourne?
    Stu
    EP82 Starlet GT - [URL="http://www.toymods.org.au/forums/forum-members-rides/71090-stus-ep82-starlet-gt.html"[/URL] SOLD
    EP82 Starlet GT V2.0 - http://www.toymods.org.au/forums/sho...98#post1514198 SOLD
    The IS400, GXE10 with 1UZ - http://www.toymods.org.au/forums/thr...8-StuC-s-IS400
    Twisted ****** Backyard Mechanic .T.'s Avatar
    Default Re: Cusco LSD transaxle oil
    the cusco is basically the same as a kaaz. in my mr2 I originally ran the kaaz oil to run it in & then switched to redline.
    I also found that "spirited" driving tended to cook the oil - resulting in regular oil changes needed.
    fyi the redline also made the lsd very aggressive, I ended up putting a friction modifyer (martini) in the oil as well to tone it down (which imporved the shifting as well mind you)
    T
    May 2011
    wont fricition modifiers shorten the life of syncro rings?
    thats what i thought, as they slipped more therefore more heat and wear?
    1990 ST185 Running stock Gen 3 power, 216awhp at 15psi. 13.6 second down the quarter
    I've heard bad things about redline and royal purple. Any ideas if these are actually founded or just net-type rumours? Considering the car's you've built and run T i actually trust your opinion
  1. Toyota FWD/RWD transaxle info...
    By Rex_Kelway in forum Tech and Conversions
    Last Post: 11-01-2013, 08:52 AM
  2. E153 transaxle with LSD Oil change
    By senn in forum Tech and Conversions
    Last Post: 31-03-2012, 10:02 PM
  3. 4A-GE (rwd) clutch suit E51 transaxle?
    By mullett in forum Tech and Conversions
    Last Post: 15-04-2006, 12:54 AM
