Results 1 to 13 of 13
Thread: Filthy Nissan help needed ASAP
    Oct 2009
    Default Filthy Nissan help needed ASAP
    Trying to get this fucking KE70 going but I cant get the motor to fire, its a CA18DET.
    I've done the required wiring (I'm pretty sure, looks simple enough) but I'm not getting any spark or fuel. The most I've gotten, I'll crank it, let off the key and get an ants cock tiny arse spark and a single injector click.
    Normally I would assume something is rooted or I've fucked up something good and proper but if I remove the CAS and spin it by hand I get spark and I can hear the injectors cycle.
    Any pointers?
    Also there is a start signal wire on the ECU, needed or can I splice it to 12v?
    Nothing but a Backyard Mechanic caam's Avatar
    Apr 2010
    Default Re: Filthy Nissan help needed ASAP
    Do you have a constant power to the ECU when cranking?
    SR20DET TA23
    Oct 2009
    Yeap, CAS drive is good too
    Oct 2009
    Calling it a day, got no fuel.
    Rail has pressure, injectors are clicking but plugs are bone dry and I dont get anything when cranking the motor with the plugs out.
    Will pull them this week and see if they are fucked, have been sitting for 4 odd years.
    Failing that, piss of this hacked shitty loom and start fresh.
    Stupid question, is the cam belt intact?
    Teen Re****** Backyard Mechanic SumKid's Avatar
    Jun 2008
    The cas locator in the cam snapped off? Seen that a few times.
    Bagged Gs430 Daily
    Ra23 Cruiser
    Oct 2009
    Cams are turning, its got a timing belt and the CAS locator is still there.
    The fact I cant get any fuel is the biggest problem, if I can turn the CAS and hear the solenoids clicking along with getting some sort of spark then the ECU should still be alright (dunno what its doing fuel wise) along with the wiring.
    I'll send the injectors off to get looked at and go from there, if they turn out to be alright I'll buy a S13 engine loom and ECU and not hack the shit out of it.
    Apr 2007
    If the only time you are getting a spark & only a small spark is when you come off the key, are you getting a voltage drop when cranking ?? & have you got the full 12 volts at the ECU when cranking & in the run position too & are all the earths good ??
    Is the battery good too in strength ..
    Nov 2011
    old cars have ign wire and 2 start wires on the ignition switch
    the second start wire used to goto coil and is normally called ballast resistor bypass
    if u have only wired up 4 or 5 wires with no relays like most forums guys
    just put all powers to battery positive and see if it starts then once it starts u can stop stressing and redo it properly with relays and fuses
    also try spraying flammable liquid down throttlebody to see if it starts and if it does then u know its fuel related
    so u either have fuel lines back to front or u have blocked injectors (very common on jap motors that have sat for awhile)
    nissans are the easiest motors to wire up so y are u streesing i can wire them in 5 minutes if u put all powers to battery hahahahaah
    try trigger each injector yourself of the battery and listen for clicking noise
    if u need an ecu i might have one for 30 bucks
    Oct 2009
    Yeah wiring is dodgy atm, I need to see if the motor runs before I continue as its history is dubious (it bent a valve before we got it, seller agreed to repair it before we picked it up, never been run).
    Went to bed last night after many beers and worked it out and its due to dickhead no1 (aka me)
    Radio cuts out when you crank........ I've got all powers switched acc
    Oct 2009
    Started first hit of the key
    Dont I feel like a knob
    at least you worked it out
    Nov 2011
    with old cars 50 % of them won't start
    cause people don't hook up the ballast resistor
    bypass wire
  1. Help Needed ASAP - Car Trailer
    By CHB in forum Tech and Conversions
    Last Post: 24-01-2010, 11:15 PM
  2. help needed ASAP
    By Bean in forum Tech and Conversions
    Last Post: 30-12-2007, 11:13 PM
