At a guess if it was good before, i would think the bottom hinge needs to be moved out where it actually mounts to the door as it sounds like it it is the cause of holding / keeping your door from sitting flush .. You should be able to get at the hinge with the door open & back off the bolts & adjust it that way, but it might be easier / better final finish wise to remove the front guard & you can tweak it & getting it linning up well ..
Also obviously make sure there are no packers / shims between the bottom hinge & the A pillar mount ..
