Results 1 to 5 of 5
Thread: 1G Heating in a RT142
    Junior Member Grease Monkey Mr Multivalve's Avatar
    Default 1G Heating in a RT142
    Has anyone hooked up their heater using the 1G GTE, it it just a matter of hooking up an inlet and outlet pipe?
    I am in Toowoomba and it is pretty cold in the mornings just wanted to know if any 1G corona owners or anyone has done this as I don't know where the pipes are situated either? There are fittings on my firewall but I wanted to know where the heating pipes come out of the 1G.
    Corona Creed:
    Good to Drink, Great to Drive, keep them separate to stay Alive!
    Default Re: 1G Heating in a RT142
    Yes, simple as that.
    There will either be two blocked off pipes at the back of the 1G, or one big loop pipe.
    Connect these to the inlet/outlet on your firewall.
    ok cool, I will try that and hope my heater is not all rusted out
    Corona Creed:
    Montrose
    Give your heater a good rinse before you connect it to shift at least some of the riverbed that will be accumulated in there rather than add it to your cooling system.
    Ok thanks will do
    Corona Creed:
  1. GA70 diff compatibility with RT142
    By Mr Multivalve in forum Tech and Conversions
    Last Post: 20-03-2006, 09:05 PM
  2. rt142 independent rear = ra65/sa63 celica
    By Mattrt142 in forum Tech and Conversions
    Last Post: 26-02-2006, 12:48 PM
  3. Rt142 rear springs etc.
    Last Post: 31-12-2005, 02:57 AM
