Results 1 to 5 of 5
Thread: 1jz jzx90-mx83 misfire
    Jun 2012
    Nsw
    Default 1jz jzx90-mx83 misfire
    hey guys, iv got a 92 mx83 cressida and iv put a jzx90 1jz into it. when i drive it just as it gets onto boost it misfires, coughs and splutters until you change it up a gear then it does the same.. could it possibly be running in limp mode ? if so how do i go about getting around it ?
    Jun 2012
    Nsw
    Default Re: 1jz jzx90-mx83 misfire
    Iv been told I have to ground my STA wire, is that correct? And do I do that via a relay? If so which wires will I be needing to use? Cheers
    May 2012
    Firstly get new plugs and gap them to 0.8mm and check your coilpacks for cracks.
    Nov 2011
    if it has a rev limit aorund 2500 or 4000 rpm it could be wired incorrectly
    have u hooked up the check engine light and tried to get codes from it
    Apr 2011
    it sounds like you have bridged the nsw and sta wires
    if its auto, you need to hook up the neutral switch using a relay, as mx83's and jzx90's use a different method of isolating the starter.
    if its manual, just hook the sta wire to your starter motor trigger wire, and leave the nsw wire. (you can do this with an auto as well, but it will start in any gear)
    and i agree with dumbass, check for codes.
    the nsw and sta wires are in the main power connector on the engine harness (same plug that has the injector power and starter wires) the sta is a thin black wire, and the nsw is a thin black wire with a white stripe.
  1. JZX90 1JZ in MX83 air con idle up
    By cybersimon in forum Tech and Conversions
    Last Post: 03-03-2013, 08:01 AM
  2. MX83 MisFire, searching for cause?
    By Mr.Matt in forum Tech and Conversions
    Last Post: 29-03-2012, 09:11 AM
  3. 1JZ into MX83 misfire at 3k rpm
    By Yammies in forum Tech and Conversions
    Last Post: 27-01-2008, 03:55 PM
  4. JZX90 suspension into MX83?
    By rossvw in forum Tech and Conversions
    Last Post: 14-10-2007, 08:16 PM
