osix theres many of datsun sites
www.nissansilvia.com
http://www.ozdat.com/forum/
datsun= funny crude poo poo
As seen in George Furys Bluebird.
Pole position at Bathurst.
Dont see many of them in Aus..
I have pictures
Rims are like chicks.. I dont touch them if their over 15
This info hunting for Z18ET is going no where-
but so far i got two feedback - One is
6km per Litre
second is _ if you work the engine hard enough - is better you buy a V8
hm...
this totally diffrent from what the seller said -- so confusing ..
osix
Originally Posted by osix
he IS trying to sell it, for a reason.....![]()
it's an old old engine with a turbo....![]()
beer me!
A friend of mine used to have a car with one, it certainly went nicely. He never mentioned lousy fuel economy though..
easy fill the tank and drive for 100km and then fill it again and look at the litres you use.
Osix,
i have the next generation eng on from that, mine is a sohc ca18et (not twin cam), it to has 8 plugs and is similar technology, and yes sir-re, dont expect to get great fuel economy, mostly due to the turbo design and the ecu's of the day. with an aftermarket ecu you will be able to turn a bit more economy orrientated on cruise, from memory with a factory ecu i use to get around 400km to 50lts if i was being a very good lil boy, otherwise that could drop to 280-300km for 50lt at the spank of a hooker. Mind you when i took turbo off and put a na exhaust manafold on, i was able to put bucket loads of timming into it and now get 600km to 50lts regulary.
Trav
Active Corolla abuser!!!
Travis Robson
0418 552 413
www.910bluebird.com
im a member here also. there is some great info to be had!
