Results 16 to 23 of 23
Thread: Sorry to ask a Non toyota engine question - Z18ET need info
    AE86 Pilot Grease Monkey skaney's Avatar
    Default Re: Sorry to ask a Non toyota engine question - Z18ET need info
    As seen in George Furys Bluebird.
    Pole position at Bathurst.
    Dont see many of them in Aus..
    I have pictures
    Rims are like chicks.. I dont touch them if their over 15
    Junior Member Backyard Mechanic sam-131's Avatar
    osix theres many of datsun sites
    www.nissansilvia.com
    http://www.ozdat.com/forum/
    datsun= funny crude poo poo
    thailand
    This info hunting for Z18ET is going no where -
    but so far i got two feedback - One is
    6km per Litre
    second is _ if you work the engine hard enough - is better you buy a V8
    hm...
    this totally diffrent from what the seller said -- so confusing ..
    osix
    tasmania
    Quote Originally Posted by osix
    6km per Litre
    hm...
    osix
    he IS trying to sell it, for a reason.....
    it's an old old engine with a turbo....
    beer me!
    A friend of mine used to have a car with one, it certainly went nicely. He never mentioned lousy fuel economy though..
    easy fill the tank and drive for 100km and then fill it again and look at the litres you use.
    Viagra Enlarged Member Grease Monkey TRAV-KE55's Avatar
    Osix,
    i have the next generation eng on from that, mine is a sohc ca18et (not twin cam), it to has 8 plugs and is similar technology, and yes sir-re, dont expect to get great fuel economy, mostly due to the turbo design and the ecu's of the day. with an aftermarket ecu you will be able to turn a bit more economy orrientated on cruise, from memory with a factory ecu i use to get around 400km to 50lts if i was being a very good lil boy, otherwise that could drop to 280-300km for 50lt at the spank of a hooker. Mind you when i took turbo off and put a na exhaust manafold on, i was able to put bucket loads of timming into it and now get 600km to 50lts regulary.
    Trav
    Active Corolla abuser!!!
    Travis Robson
    0418 552 413
    south australia
    www.910bluebird.com
    im a member here also. there is some great info to be had!
  1. Toyota Engine Codes Explained
    By wagonist in forum FAQ
    Last Post: 16-12-2015, 11:21 AM
  2. Toyota R Engine History
    Last Post: 02-12-2011, 08:41 PM
  3. Toyota Crown MS63 Custom Wagon Info
    Last Post: 28-09-2007, 12:31 PM
  4. MA70 --> JZA70 Conversion
  5. Toyota Model Codes Explained
    Last Post: 14-10-2005, 09:47 PM
