These are images off my JZX81 1JZ-GTE (it’s a 92 engine as well so should be similar).
I have added colours to differentiate different lines that I am talking about so look down for the images (I have done your pics as well where I have known what they were)
1. Fuel Damper (mine is mounted on top of the fuel filter which is mounted to the block). Yours looks like it’s from a JZZ30 which have them under the chassis somewhere so the damper is alone on the block.
2. Looks like it’s from the blue solenoid under the intake manifold (shown in pic 6)
3. Forward one is a spare which is usually used for a boost gauge, rear one is the Red in my pics
4. Two lines go into the blue solenoid (one line is pink in the pics, the other one goes to the intake manifold just above the map sensor port)
5. It goes to the map sensor (it’s the line next to the pink one in pic 5 and loops around to the sensor which is at the top of the pic, upsidedown)
6. Goes from the ISCV (big black thing in the pic with the grey plug) to the rear turbo intake (Dark Yellow in the pics)
7. That line is the vacuum line for the brake booster
Red - boost feed for BOV
Dark Yellow - ISCV return to pre-turbo pipe
Green - Breather from intake cam cover to intake manifold
Pink - line to solenoid from manifold - also Tees to throttle body (not sure exactly where)
Brown - from ISCV to throttle body
Blue - water inlet from heater core
1
2
3
4
5
6
7
