Results 1 to 10 of 10
Thread: 2tg head gasket size question
    Too old to be a Grease Monkey
    Aug 2008
    Default 2tg head gasket size question
    Hi All,
    Need an answer to a probably silly question.
    If I have a set of 86 mm pistons and a block bored appropriately. Can I use a standard head gasket for this build?
    It looks like it suits but would like to make sure?
    Pretty sure that the block I got the pistons from when built had a standard head gasket so someone has obviously thought it ok in the past?
    Any comments from the experienced 2tg builders?
    Nathan
    Feb 2012
    Aberdeenshire
    Default Re: 2tg head gasket size question
    If it was me I would use a std gskt. Once you go past a 1mm oversize you run in to problems.
    I did use a std gskt on a 89mm bore but it only lasted about 2,000 miles.
    I did it to get home and whilst I was waiting for one made......I now have a 90mm gskt on a 89mm bore.
    Feb 2012
    Aberdeenshire
    Junior Member Domestic Engineer 71TA22's Avatar
    Carterton
    Standard head gasket should be fine for an 86mm bore.
    All the standard head gaskets I have measured have a 87mm holes in them.
    Mike
    71 TA22
    My Car
    VAASA / FINLAND
    Yeap like Mike says, up to 86mm with no worry, just install it. And diam of rings at HG are 87++mm
    With 86- 87mm pistons had to check that headgasket properly match to a block. I have put small drops super glue to the gasket corners to keep it in a place. Sometimes those pins in a block had some clearance between gasket, so they do not always hold the HG in a correct place with 87mm bore.
    I have always use stock HG in N/A engine (87bore) without problem, but seen that they do not always match properly to the block
    - Celica TA-22 -74 2T-G Turbo
    - IQ 1.0 -09
    - Lexus IS250 -06
    Feb 2012
    Aberdeenshire
    The reason that I had a problem using a std gskt in my 89mm block was that the lip of the gskt just overlapped the bore .....the piston top was level with the block and the piston domes were recessed from the edge....but the heat of combustion melted the metal lip of the sealing ring and it split.
    I knew it would do it but I needed to travel 350 miles home and it made it...luckily.
    Not to be recommended.
    I think 87mm would be the maximum you could get away with.
    Aug 2008
    Thanks again everyone,
    I have read that you use a little sealant around the water housings.
    Do you guys do this too? What sealant is recommended for NA build?
    Nathan
    VAASA / FINLAND
    I have Never use sealant to water passages, only a littlebit where is timing cover joint to the block.
    - IQ 1.0 -09
    - Lexus IS250 -06
    Feb 2012
    Aberdeenshire
    Agree with Kujala........only where the gasket sits over the timing cover. I use Hilomar.
    Aug 2008
  1. any one know about subarus ? head gasket question
    By Suavemechanic in forum Tech and Conversions
    Last Post: 11-12-2011, 05:01 PM
  2. HKS 4AZGE Head Gasket Bore Size
    By Duk in forum Tech and Conversions
    Last Post: 17-02-2010, 01:52 AM
  3. 4agze head gasket size?
    By johan_oern in forum Tech and Conversions
    Last Post: 25-09-2009, 04:29 AM
  4. Head gasket replacement question
    By CHB in forum Tech and Conversions
    Last Post: 23-09-2008, 06:33 PM
  5. Head gasket question
    By chubbylover53 in forum Tech and Conversions
    Last Post: 22-04-2006, 05:08 AM
