Results 1 to 15 of 25
Thread: aw11 fuel pump
    tasmania
    Default aw11 fuel pump
    hey guys just wondering if anyone has had problems with the efi fuse blowing.
    i replaced it and it just keeps happening. i have checked for shorts in the wires but everything is good.
    the other question is does anyone know why when i re-wired my pump it runs at 60 psi, this is still the standard pump, is it maybe 6 volt?????
    my car wont obviosly run at 60psi it just floods as you would expect.
    any info would be great....
    thanks.............
    Default Re: aw11 fuel pump
    did you go threw a relay for the fuel pump?
    The fuel pump doesn't control the fuel pressure, that is the job of the pressure regulator. If you're getting 60psi fuel pressure then you need to sort out what is wrong with your pressure regulator.
    Why did you rewire the fuel pump?
    Oh and the fuel pump is definately 12V.
    tasmania
    hey guys to answer some questions i wired it with a relay, i am rewiring it because it keeps blowing fuses as soon as i switch the key to ignition, and i know it does not regulate the pressure the fuel pressure reg does i have tried the factory reg a malpassi fpr and also another aftermarket one... and it still runs at 60psi at the lowest...
    i was hoping to rewire it as a quick fix but now it wont start due to the huge fuel pressure...
    any other ideas...........
    did you put in a bigger pump? if so it may be to big for the return line.
    tasmania
    na it is still running the same pump.
    the car was running fine up untill a week ago when it started blowing fuses..........
    please somebody............
    It couldn't be something like a blockage in the return line could it?
    the only thing i can think of is a blockage{restriction} in the return line somewere. you pump might have been blowing the fuse on overload.
    hahaha were twins ben!
    tasmania
    any ideas on how to check or get rid ov the blockage....
    mmm an air compesser blowin thru the return???????
    Try hooking up your return line to go into a bucket or something and check the rail pressure then. Make sure it is the problem.
    also could be your fuel filter is soo blocked and dirty that it could be the blockage? causing higher pressure
    89' MR2 AW11... His
    00' MR2 ZZW30... Hers
    A blocked fuel pump would cause higher pressure between the pump and the filter not not in the fuel rail itself.
    Quote Originally Posted by Joshstix
    A blocked fuel filter would cause higher pressure between the pump and the filter not not in the fuel rail itself.
    fair enough, hmmm got nothing then, sorry
    89' MR2 AW11... His
    tasmania
    hey buys any other ideas, i tested the fuel return and its all clear. it is also not the fuel pump that is the problem because i unpluged it and it still pops the fuse.
    could it be the ecu.....
  1. HELP - how to wire up a fuel pump
    Last Post: 21-06-2007, 12:15 PM
  2. weak fuel pump? (1jz-gte lost alot of power)
    Last Post: 23-01-2006, 08:14 PM
  3. aw11 fuel pump ???
    Last Post: 25-12-2005, 02:31 PM
  4. Replies: 1
