Results 1 to 11 of 11
Thread: RA40 Rear Wheel Bearing Part Number
    Aug 2011
    tipperary
    Default RA40 Rear Wheel Bearing Part Number
    Anyone know the NSK part number for wheel bearing of RA40? The 7.5'' F312 type axle
    Melbourne Victoria
    Default Re: RA40 Rear Wheel Bearing Part Number
    same as ae86
    Aug 2011
    tipperary
    Thanks, PM sent
    Melbourne Victoria
    ok is yours a 18rg with a disc brake rear end or are they drum brake .if drum brake same bearing as ra23 ra40 and ra60 single race bearing
    the dics brake rear end came out with a dual race big bearing
    Aug 2011
    tipperary
    Quote Originally Posted by Celica RA45 View Post
    Ok, never seen 1 with rear disc brakes in Europe, I modified my 1 and added discs!
    Melbourne Victoria
    ok have taken pic of my disc brake rear axle
    Aug 2011
    tipperary
    Thanks Celica RA45, I never seen these on Celica before! These are the type that Weir Performance supply, unfortunately they wont fit my axle! Going to try and make it fully floating now! Even though I never had trouble before I don't think the 30 year old shafts I have will put up with the power I'm gonna have with new engine I'm getting built!
    Melbourne Victoria
    im putting 340hp through my rear end and havnt broken a bearing or axle ,those pics are my spare axles
    Melbourne Victoria
    then just buy the axles and get the bearings over where you are
    also if you have gone to disc brakes with a single race bearing ,you will get disc chatter when you go around corners .some bearing companys made a dual race bearing that was 10mm wider than the std single race bearing /that would be a better option ,and you would have to make a 10mm spacer a copy of the gasket and use longer bolts to go through the end sections
    Aug 2011
    tipperary
    Some power that, what engine have you? I'll measure up bearings and see can I fit 'my type' bearings to Weir's shafts! I'm racing a long time and never had problems with disc chatter.
    Would you e-mail me some pics of your car, PM sent?
    Melbourne Victoria
    all of the f series are the same dia for the bearings for single or dua race set up
  1. SC14 pulley bearing part number?
    By Munki in forum Tech and Conversions
    Last Post: 11-03-2012, 01:02 PM
  2. Wheel Bearing-Need another part number
    By richzx in forum Tech and Conversions
    Last Post: 19-03-2009, 09:48 AM
  3. Part number for R154 rear seal
    By Hengsta in forum Tech and Conversions
    Last Post: 31-07-2008, 11:29 AM
  4. 3sgte Spigot Bearing PART NUMBER NEEDED
    By medwin46 in forum Tech and Conversions
    Last Post: 11-01-2008, 05:39 PM
  5. jzx90 mark2 wheel bearing wat asus car has same part
    By tourer.v in forum Tech and Conversions
    Last Post: 08-08-2006, 06:11 PM
