Results 1 to 3 of 3
Thread: MS123 Crown overdive computer location
    Jan 2013
    Tasmania
    Default MS123 Crown overdive computer location
    HI Folks!
    Can anyone tell me where the overdrive computer is located on this car.
    It is an early 1984 without an ECT.
    Any help appreciated.
    Have a good day!
    Nov 2011
    Default Re: MS123 Crown overdive computer location
    something that old would prob not have an ecu
    i know some hiluxs had a transmission relay
    basically all it did was convert a neg trigger signal from the overdrive button
    to a positive signal down to the overdrive solenoid on the gbox
    some hiluxs also had a temp sensor on gbox which would not let overdrive engage
    till the auto trans oil got to a certain temp
    As said, overdrive is simply turned on and off with a switch, which usually has a temperature switch in series with it to stop the auto using overdrive when it is cold :-)
    Wilbo's JZA80
    Wilbo's JZZ12
  1. AE101 4AGZE Computer Location
    By PuGZoR in forum Tech and Conversions
    Last Post: 12-10-2006, 06:06 PM
