Results 16 to 30 of 55
Thread: Moroso 4age baffled sump group buy
    perth
    Default Re: Moroso 4age baffled sump group buy
    add me to the list to.
    cheers.
    Jul 2008
    Auckland
    Quote Originally Posted by SRacin View Post
    Cool. I'm in. Also think there is a bunch of people down here in Christchurch in the car club that would be super keen. It would be good if the flat section allowed the engine to be lowered also.
    Its going to be the same as the OEM sump in that section, as your know its already shallow!
    Quote Originally Posted by fixeruperer View Post
    cheers.
    There is a link above to place a deposit.
    Now 9AGTE 410kw atw
    perth
    Jul 2008
    Auckland
    Fixed!.....
    Now 9AGTE 410kw atw
    hrmm... who do i talk to about freight costs?
    Jul 2008
    Auckland
    Quote Originally Posted by feral4mr2 View Post
    Freight on this I wont know until I get them. It goes on weight.
    But 5kg is around $50-60NZD
    Now 9AGTE 410kw atw
    New Zealand
    Hi Bazada,
    Is this all go and do you have a timeframe from moroso yet?
    Jul 2008
    Auckland
    Yep Moroso are still working on the design. Trying to get 1 sump that fits all. 16v and 20v.
    Hope they are done soon! they will update me next week.
    Now 9AGTE 410kw atw
    Jul 2008
    Auckland
    The sump design is nearly done! just making a few changes to the intake side kick out section as it wont fit FWD or MR2 with how big it is atm. So going to make that side a little smaller.
    The flange on the sump will work with both 16v and 20v blocks (of course 7a as well).
    A custom windage tray will have to be used with the 16v sump as the indent for the 20v block on the flange would interfare with the 16v windage tray. Or you can cut a small section out of the oem windage tray with some tin snips!. Moroso are going to design a windage tray to suit any how.
    Also when using the sump on the 16v block the kit will come with a block off plate to cover over the 3x bolt holes used on the 20v blocks.
    Now 9AGTE 410kw atw
    perth
    So it's pretty much for 20v's blocks.
    I may as well mod a stocker.
    Jul 2008
    Auckland
    Its for both blocks. To allow 1 to fit all this is how the design is done.
    As for the windage tray we can integrate the windage tray into the sump which bolts in and out. So that means you dont need to OEM windage tray which is quite a pain when putting the sump on. I think this is a better option!
    Also these sumps have a much thicker flange (6mm thick) which also heps with block strengthening if your not using our crank girdle system. Plus the internal baffles and flaps have been properly designed and are not just thought up out of the blue.
    Now 9AGTE 410kw atw
    Feb 2010
    Auckland
    It's times like this I wish this forum had a "like" button
    Jul 2007
    Will the windage tray clear the stroker crank and girdle etc?? Good to hear about the sump working on 16v too. Means I can bolt it onto my current 16v engine till the 9agte 20v is done
    Oct 2009
    Ummm if your exhaust clears the stock sump will it clear this?
    Mine has about 5mm of clearance....
    Not a problem for AE86 guys but not being able to run off the shelf extractors without chopping them up is a minus
    Jul 2008
    Auckland
    Yes it will, there will be a 5mm spacer when the tray is installed, you remove it for 7A applications.
    Now 9AGTE 410kw atw
  1. RWD 3sgte baffled sump
    By af300e in forum Tech and Conversions
    Last Post: 24-07-2008, 10:07 PM
