Results 1 to 10 of 10
Thread: GX71 Mark II ( 1G-GTEU questions )
    Aug 2012
    Florida
    Cool GX71 Mark II ( 1G-GTEU questions )
    Car specs:
    1985 Toyota GX71 Mark II GT Model
    Twin turbo 1G-GTE engine
    24 valve twin cam
    OEM 2 way 8 inch LSD differential
    Suspension:
    Front: JIC front coilovers with camber plates
    Rear: AE86 suspension
    Wheels:
    Rare SSR MK1's
    front:14x8 -0 offset 4.5 inch lip
    rear: 14x9 -25 offset 5.5 inch lip
    I think this is the only GT in the states so I have a couple of questions on the car.
    1) The 1g-gteu is not an engine that came to the U.S. so what can I do to the engine to modify and achieve 300hp?
    2) The car still has the bozo 1.5 inch straight exhaust from Japan so should I go for 3 inch or 2.5?
    3) I'm actually working on the rear end installing new boots, wheel bearings and brakes but there's no parts for this car here so what parts interchange with the rear end and brakes for this car. MX73?
    4) How special is the GT model and what's so special about it, any info you guys can provide on the car I would greatly appreciate it.
    All right on with the pics:
    Aug 2012
    Florida
    Default Re: GX71 Mark II ( 1G-GTEU questions )
    I was sent here cause you guys are the 1g-gte gurus.
    Anybody?
    Jan 2011
    There are quite a few people on here with detailed build threads for the engine, do a search of the members rides threads. Lots of 1g's pulling ~200rwkW.
    Can't help you with the body stuff I'm afraid but you might find something in the interchangeable oddities thread.
    Love the car by the way. Nice interior too.
    One thing you might try is the toyodiy website. If you can find your model car on there, you can lookup part numbers and it will give you a list of the vehicles the part was common to.
    Junior Member Backyard Mechanic scottreichstein's Avatar
    Aug 2011
    if your looking for power get rid of the twin turbos and put on a larger single around gt28 and larger injectors
    ive gone kkr380 turbo
    440cc 7mgte injectors
    xf falcon throttle body
    custom plenum
    3 inch turbo back exhaust
    full aftermarket computer
    electronic ignition eg coil packs dizzy as CAS
    im hoping for around 170 rwkw at 14psi
    the motors are good for up to 240rwkw before they blow
    but the norm is around 200rwkw at bout 17-20 psi
    RIP st141 died doing what it loved http://www.facebook.com/media/set/?s...type=3&theater
    1ggte hilux massive 143rwkw http://www.toymods.org.au/forums/sho...724&highlight=
    corolla sportivo daily LIFT
    Aug 2012
    Florida
    Quote Originally Posted by scottreichstein View Post
    custom plenum
    I want to go single turbo but finding a manifold in the U.S for the 1G is nearly impossible so what manufacturer can I get a manifold from?
    The 7m 440 injectors I can get but are they a direct swap or is there any mods involved?
    Aug 2011
    the injectors are a straight swap but i know the signal is wrong but not 100% sure how to correct this
    you can always pull the existing turbos off and get a y piece made up to mount a single turbo onto
    that way you can have your height and angle made up to suit wherever you want the turbo to sit
    i made my own it was pretty straight forward
    just have a look at my hilux build and there are pics of it on there to give u an idea of what im talking about
    NICE VIBE Backyard Mechanic marvis's Avatar
    Aug 2008
    8" diff would be G Series? MX73/MA61 etc. is F series @7.5.
    THIS CAR IS FUCKING AMAZING..
    Except for that roll cage, make it yellow. Seriously.
    Jan 2011
    Nope, cage is great right now
    Jul 2011
    Quote Originally Posted by yellow_feva View Post
    Try looking on yahoo japan, there can be found some manifolds from time to time or have a custom one made up
    Jul 2011
    PM sent
    check your inbox
  1. Find that gx71
    By hi_rolla in forum Western Australian Events
    Last Post: 23-06-2012, 03:35 PM
  2. 1G-GTEU help please
    By cagiva97 in forum Tech and Conversions
    Last Post: 13-03-2008, 07:57 PM
  3. NEEDED!: gx71 mark II wiring diagrams!!
    By sticky667 in forum Tech and Conversions
    Last Post: 06-09-2006, 04:57 PM
