Results 1 to 6 of 6
Thread: E58 gearbox help
    Mar 2012
    Default E58 gearbox help
    Hi I have a e58 gearbox of an ae92 4agze it is not an LSD. Does anyone no if I can makes this gearbox an LSD i know cusco make anLSD for an ae92 4agze but I'm not sure if this is just a replacement for an already LSD gearbox or it will suit a non LSD gearbox.
    Sep 2009
    Default Re: E58 gearbox help
    You can fit a LSD. What is the end cover made of? Is it aluminium or a pressed steel black cover? Do you have the drive shafts to go with the Gearbox? I think all you need it the left pot joint out of LSD to convert it if you dont find a LSD that suits a non LSD car. I bought a used Cusco off Ebay last year.
    You might want to have you gearbox pulled down to check the condition. I have a couple pulled apart until I found one worth rebuilding. If you want to change the diff ratio, you can use the final drive gears out of a Rav4. I used the ones out of a 2az engined one and they were 4.5:1. Which is a similar ratio to a silvertop ae101. Also you can find 4.9:1 out of earlier Rav4's .
    Oct 2009
    Kazz make one that will fit the non LSD gearbox
    Jul 2007
    kaaz/cusco/TRD mechanical diffs all use the "non LSD" driveshafts.
    Chiba
    Quaife also make a very nice torque biasing diff too. No nasty lock up with those ones.
    Jul 2007
    depends on the application. for a street car a torsen is definitely the way to go, but for track work i wouldnt consider using anything less than a clutchpack diff.
  1. hiace gearbox conversion problem. gearbox way too small
    Last Post: 28-12-2007, 11:59 AM
