Results 1 to 6 of 6
Thread: 4agte with standard distributor ignition setup
    Hachi Rusto Backyard Mechanic Julz01's Avatar
    Default 4agte with standard distributor ignition setup
    Hey Guys
    I am going to be doing a 4agte on my current NA JDM Bigport 4age. Just looking to run low boost for the moment in its current form so the bottom end doesn't go bang.
    Ive been doing a heap of searching the last couple of days to try and work out if anyone has done a 4agte setup with a normal dizzy as apposed to going to a 4agze CAS setup.
    I was going to get some GZE injectors and then try control the fuel with SAFC.
    If anyone could shed some light on this that would be great and any other information that would be great.
    thanks
    julz
    Default Re: 4agte with standard distributor ignition setup
    Yep, I did exactly what you are planning with a smallport 4age.
    Standard dissy system worked fine.
    I actually replaced the ecu with a gze one, with matching injectors and map sensor... and then added an emanage.
    Honestly, just get a second hand adaptronic or similar. For the effort of fucking around with an safc or emanage, it's not much more cost to go full stand alone, and the result is much more reliable and better all round.
    ...... butt scratcher?!
    so you replaced it with a non afm 4agze ecu?
    With the adaptronic would I still be able to run the standard distributor or would it be better to go the 4agze cas setup?
    I've been running a AE92 Smallport as 4AGTE using the stock distributor setup for years and it hasn't missed a beat. I run around 12psi (using GZE pistons) with the stock 100kW ECU and an eManage blue. For injectors I'm using the light green 1GGTE ones as I didn't want to bother with using resistors for the GZE injectors. Car runs great and was a good cost effective way to do the conversion, got to keep all the original wiring and sensors too.
    Jul 2007
    you can use the smallport distributor as a cas. they are the same internally, just get rid of the rotor button and make up a smaller cover for it if you want...
    Fear the Rapeodile Carport Converter blakeg's Avatar
    May 2006
    yes you could run the stock dizzy with an adaptronic or other ecu also, my 3s is running the stock dizzy, coil and ignitor on the adaptronic
  1. Early 4a ignition coil and distributor
    Last Post: 16-01-2011, 12:25 PM
  2. Toyota Distributor and DLI Ignition Systems - explanation and guide
    Last Post: 14-11-2010, 02:42 AM
  3. Distributor Ignition to DFI using Emanage Ultimate?
    By Duk in forum Tech and Conversions
    Last Post: 02-02-2010, 06:59 PM
  4. Replies: 0
    Last Post: 20-07-2006, 01:18 PM
