Results 1 to 11 of 11
Thread: Redtop beams oil filter replacement problem
    Bottled up Domestic Engineer charliechalk's Avatar
    Default Redtop beams oil filter replacement problem
    so I replaced the oil filter with a valvoline v07, and now it dribbles a tiny bit whenever run out the oil filter
    did it up hand tight then a quarter turn with a strap wrench thing after lubing the rubber seal
    so, not tight enough, or is it just the filter and should go and get a genuine even though they suit all the same models?
    quick help appreciated will be working on it tuesday
    Default Re: Redtop beams oil filter replacement problem
    part number from toyodiy is 90915-10001
    Jun 2008
    The oil filters I use all say 2/3 turn except for my Mitsubishi Magna which the manual says to tighten to 13ft/lbs (this is the only filter I have ever seen with a specified torque).
    Nov 2011
    Vavoline and repco filters leak around the crimp. End of discussion
    His. 2005 GRJ120 Prado VX
    Hers. 1995 KZN130 Surf (soon to be replaced by a Rav4)
    1981 LN40 Hilux Trayback ute. Now an RN40 with Surf interior
    1992 Factory Widebody 2door Surf 1UZ-FE V8 Auto, now for sale
    Aug 2009
    Ryco or genuine.. Problem solved id imagine
    thanks all, well if it doesn't sort itself out i guess i'll go to toyota and get a filter and change the oil again.
    Melbourne Victoria
    also might have damaged the rubber o ring by overtightening
    Make sure the seal from the previous filter isn't still stuck to the block - made that mistake on the AE82 ones, everything seemed alright when filling the oil up and on initial startup, right up until it dumped its guts all over the driveway.
    Jan 2008
    queensland
    Quote Originally Posted by 4th surf View Post
    amen +1
    neil
    2009 aurion
    Purple 2000 Hilux - 1UZ
    well it stopped leaking after two tiny dribbles, will be keeping a close eye on it, might have just been some that was stuck on the outside lip or it needed to cool to seal properly
    either way problem solved i guess.
    Junior Member Conversion King
    May 2010
    Quote Originally Posted by Hiro View Post
    +1 for this too. I know of a dealer doing this to a friends car on its first service. Short story they starved the engine and ruined it, were liable for a new one.
  1. uzs131 oil filter replacement. Tips?
    By desty in forum Tech and Conversions
    Last Post: 24-05-2011, 10:53 PM
  2. beams redtop idle too high
    By aw11man in forum Tech and Conversions
    Last Post: 29-05-2007, 10:59 AM
