usually you measure where the hose is put on, not the threaded section
Hi guys,
need a bit of clarification regarding some AN sizes if anyone can help.
first off, I have these fittings, which I wanted to replace
after measuring I looked at a AN size chart
which made me think that the size is AN-12
Is this correct?
Because when I went ahead and ordered some AN-12 fittings, I received
Which to me looks like AN-16.
so I emailed the seller with these pictures, and they have told me "We sent you AN12. The measurement is correct and match the AN12."
Am I retarded? what is the correct way to measure AN fittings?
Merlin
Hi Merlin. AN fittings you measure od of male thread or hose id. As the chart above has listed AN-12 is 1 1/16 inch od thread or 12/16 or 3/4 inch hose id, which if you had a set of verniers will show that size.
You have the basic idea correct. You are not retarded quite a few people get confused with AN sizing.
Regards
Tony
So based on this picture, where I measure the OD of the male thread to be 25.4mm / 1 inch
this is AN16 right?
Thanks for all your help guys
Try Aeroquip's WWW or any other real manufacturers, not some re-seller site or the makers of all that colorful wannabe stuff.
Looks like you got sold AN16. I used that chart when doing my turbo/oil cooler lines. I bought all proflow stuff through work tho. Not bad, but not as good as speedflow. The speedflow design is better, but havent had any problems with proflow and after a couple they get easy to put together.
2jza70 Conversion finished, 456rwhp : 340rwkw @ 20psi
Thanks guys, will definitely be looking into more quality items now.
Screw this aluminium shit, just buy cheap steel JIC fittings and get them crimped.
