[QUOTE=bundy;1492721]has anyone done it or will it not work?[/QUO
come on people someone has to know?
No unfortunately it won't work , do you have a bundera r151 F, I'd swap a g52 for it
.Dave
As Dave has said.. No
But if it came off of the back of a non turbo diesel then you will be looking at a G series so you need to confirm which box you are looking at, Drain plug position is a good way to confirm
His. 2005 GRJ120 Prado VX
thanks for the reply do you no the reason of it not working!.is it possible to change bell housings over. i have a g52 in my bundy now . i want to convert it to the stronger r151f.the part i dont understand is that the 2lt non turbo deisel bundera runs a g52 same as mine .but the 2lt turbo runs a r151f how do they get these to fit over the two motors with the same gearbox. so in thoery if g52 fits on 2lt the r151f should fit the 22r.am i missing something .can anyone explain please
.Dave
They don't make a bellhousing for an R series engine to mate to a R series box unless you wanted to custom design one that's why it won't work. Dump the 22 r for a 3 rz and then you can get a bellhousing to a at it to a R box.
Dave
[QUOTE=cambelt;1493608]They don't make a bellhousing for an R series engine to mate to a R series box unless you wanted to custom design one that's why it won't work. Dump the 22 r for a 3 rz and then you can get a bellhousing to a at it to a R box.
Dave[/QUOTE
This is not entirely true what about the 22ret the turboed 22r motor that has a
R151f behind it in a hilux but that is 2wd. the reason i want to keep the 22r is because i just rebuilt it and is running beautifully
an update i have sourced a 22ret bellhousing just waiting on it. ive measured it all up looks like everything will go together without many issues .i maybe the first person to do it !!!!
Bringing this back from the dead..a really late update..got bellhousing everything bolted up same clutch and all..really happy also put 55% reduction gears in...goes great now..
good work mate. another way this could have been done if there was no bellhousing is use an auto bell and adaptor plate. are you turboing the 22re at all?
Good job on the bell housing , was it just the US that had the 22 ret ?
The R 151 doesn't shift as good as a G52 but is a ton stronger .
A great mod for the G 52 is to use the gear set out of a late model G 55 hi ace box , wider gears and wider roller bearings .
Dave
