Can I use the stock 4speed column shift box? Do the 2r and 18r have the same bell housing/gearbox bolt pattern? = NO
If I do need to go the floor shift gearbox route what is the easiest way to measure where the hole needs to be? = Measure or Guess
Is the rt40 master cyl big enough to push a w50 slave cylinder? = YES
Has anyone got the 18rg to fit with extrctors? = Not with of the shelf Celica/hilux Extractors they hit the firewall before even fitting never tried Later GT corona ones They may always had to modify or get custom
