Results 1 to 9 of 9
Thread: 1jz-gte random misfire when cold only.
    Nov 2007
    Default 1jz-gte random misfire when cold only.
    Hi Guys,
    My 1jz-gte is running perfect apart from a little Issue that isn't much of a problem as it only does it sometimes when cold, ussuallly after a drive up a few streets then come to lights and am waiting,
    it would idle smooth as silk then out of nowhere a misfire, then another one, then idle great. When it warms up it never does it ever.
    Tried Different ECU that was good.
    Replaced Coilpacks
    New Spark Plugs and tried different types and gaps
    Coil Pack Connectors.
    Igniter.
    Tested Throttle position sensor resistances to spec
    New Oxygen Sensor
    New Map Sensor
    The motor is Mint and runs great and has so much power, no hesitation when driving or anything like that,
    It's like it comes on when it wants, but only when slightly warm, does not do it right from a cold start in the driveway,
    does it when it's warmed up a little bit but not fully warm.
    Could it perhaps be a crank angle sensor, I have an oscilloscope, would it show some weird readings during the misfire if it's a Crank sensor problem?
    May 2010
    Moscow
    Default Re: 1jz-gte random misfire when cold only.
    If you insist on dodgy CAS try first to clean it thoroughly from metal particles that its magnet can, in theory, attract from somewhere
    Best of all find someone with a scanner and see what happens upon your misfires. If you're lucky you will see some sensor's signal changes instantly and then settles back, for example this can be the case with coolant temp sensor.
    I've personally seen live data from 1jz-ge's off jzs171 and jzx100 and if you got a laptop you can arrange your own scanner for under $50. Don't know though if earlier models support scanners.
    Another possible option to find a faulty sensor is to disconnect sensors 1 by 1 forcing ECU into failsafe mode and see if problem disappears. Virtually every sensor can be disconnected this way while engine would still keep running.
    Nov 2007
    Motor is off a JZZ30, Could I buy a Scanner for this?
    May 2010
    Moscow
    Buy? Probably yes, but better diy
    use software from the bottom of the page below
    http://primavistalab.com/myengine/
    and here's your interface cable
    http://a.d-cd.net/90c7d8u/960.jpg
    this one will work for most of toyotas produced before 1996, and some very limited list of 1996-2000 models
    BK Grease Monkey bk_'s Avatar
    I've built my own hardware-based "scanner" (OBD reader) many years ago.
    You're not going to get much out of it since the data update interval is only ~1.25 seconds.
    Best to get error codes out of the ECU.
    Does the problem happen after a battery reconnect?
    Only on idle?
    Manual? Auto?
    Gangnam style Automotive Encyclopaedia beatle's Avatar
    Perth
    water temp sensor in the upper coolant hose hard pipe
    ECT sensor could be open-circuit / shorted as hinted by beatle.
    However, that is only a possibility if you have severe cold start issues.
    Perth
    Mine started as a miss during warm up before going shitty cold start.
    Only about $20-30 for a tridon one, considering how much youve spent so far its cheap.
    Also clean/ test the idle speed control valve
    Perth
    It sounds like its not quite transitioning from cold start mode right.
  1. 1MZ V6 misfire/surging when engine cold
    By 1JZ-Rolla in forum Tech and Conversions
    Last Post: 17-07-2010, 09:03 PM
  2. 4af misfire
    By smiley_666 in forum Tech and Conversions
    Last Post: 27-05-2010, 09:17 PM
  3. 3s-fe misfire
    By ecko in forum Tech and Conversions
    Last Post: 21-05-2007, 04:32 PM
  4. misfire or pinging?
    By -==L=a=N=c=E==- in forum Tech and Conversions
    Last Post: 14-03-2007, 02:00 PM
