Results 1 to 6 of 6
Thread: 3RZ owners please help!!
    Jun 2011
    Default 3RZ owners please help!!
    I've got a 3RZ-FE out of a 2000 model hilux I just need to know what colour wires go into which end of the IAC valve plug under the throttle body I accidentally pulled the plug off wires while removing throttle body.
    Theres 3 wires going into the plug think the plugs grey under throttle body the plugs vertical if someone can tell me what colour wire goes at top and bottom would be big help. Its not the Black plug on side of throttle body thats the throttle position sensor.
    If anyone has any suggestions on why my 3RZ is idling high 1250rpm please share your experiences I heard the IAC valve gets sticky and stays open letting air in speeding idle up. I cant find any vacuum leaks etc anywhere else its an engine conversion into an Rn110 hilux.
    thank you
    May 2010
    Moscow
    Default Re: 3RZ owners please help!!
    got some diagrams for the 3rz of that era
    the valve has 2 windings.
    touring hiace:
    1 b to ecu
    2 b-y+12v
    3 br to gnd
    95 landcruiser: the same, except #1 is R-L,#2 is B
    97 hiace regius:
    1 g-r to ecu
    3 g-y to ecu
    2 b-y to +12v
    #1 pin is to the left when you look at the loom plug
    Nov 2011
    start motor and get a test light
    make sure wires dont touch each other
    one wire will have 12v
    that should be the centre pin
    then the other two u have 50 50 chance to get it right are the outer ones
    wire it one way then if it idles crap swap the two outer ones
    Nov 2011
    And what is said above but be careful as the wiring seems to differ from Thai to jap build
    His. 2005 GRJ120 Prado VX
    Nov 2011
    just looked at my aussie workshop manual
    pin 1 is black with red trace idle speed open
    pin 2 is red with blue trace 12v power
    pin 3 is white with blue idle speed close
    Jun 2011
    Thanks mate that looks right I'll do it this afternoon see if it idles any better.
  1. 1jz Owners...
    Last Post: 11-03-2008, 05:24 PM
  2. 1JZ/2JZ owners, ever seen this?
    By Norbie in forum Tech and Conversions
    Last Post: 29-10-2007, 09:48 AM
  3. Att: Gt4 Owners
    By jemason in forum Tech and Conversions
    Last Post: 31-08-2006, 10:38 AM
