Page 1 of 3 123 LastLast
Results 1 to 15 of 44
Thread: 7m noise.. please help
    Default 7m noise.. please help
    developed a noise driving tonight.. Wasnt even driving it hard..
    Noise is sort of like a faint knock only heard above 3 grand..
    Occurs more under load, but can be heard very faintly free revving..
    Tappety noise but louder
    Its not blowing any smoke out exhaust.. ie. not a serious knock (no oil past rings)
    Any suggestions??
    possibly loose harmonic balancer bolt?
    happened before..
    Thanks
    Stomps
    Default Re: 7m noise
    Does it increase with revs? Like the frequency?
    SHE LIVES!
    Default Re: 7m noise.. please help
    not really, why?
    what you thinking... i can take it
    Stomps
    if the noise frequency (not pitch) doesn't increase with engine rpm, then it may not be engine.
    if it increases with road speed, it could be gearbox or drivetrain...
    if it's valve train, it will be half the speed of the bottom end, and if it is one of the ancilliaries, it will be a different speed again
    big end bearing? (ok, I'm just trying to freak you out)
    BHG between cylinders? it is the poo motor
    compression test to be sure?
    can you get someone else to rev and try and get an idea of where its7 coming from?
    Quote Originally Posted by Draven
    Thanks... im hell tired, just finished work.. quickly read that and just about shit myself.. top effort for waking me up though..
    I reckon the noise would be worse if it was something that bad..
    I think its deffinitly engine, sounds like its coming from the front.. maybe it does incerase with revs, but not by as much as the revs..
    Stomps
    edit.
    got a steel head gasket, not heating up at all..
    it started happening after i drove for about 30 mins, switched the car off for about a min, then drove it again... if that helps
    it could be something as simple as a tensioner pulley bearing... really the only way to tell for sure is to get someone else to rev the engine while you have a poke around with a stethescope/screwdriver
    yeah i might have to chuck it up on a hoist and have a listen..
    The last time it made a noise like this it was the harmonice balancer nut came loose.. Same sort of noise but not as frequent... yet.. i will have to check tomorrow.. its dark and cold outside.. and there is wolves after me..
    cheers for the help, keep it coming..
    P.S WTF are you people doing awake, its midnight here so its like 2am eastern time aint it? dont you people sleep..
    Stomps
    stu is in japan, nfi what time it is there
    I have 10,000+ words worth of assignments to write, plus a research propsal for a doctorate (40,000+ word thesis)... so no, in the next 2 weeks I probably won't sleep much
    in that case i REALLY appreciate the help, well i got uni in a little under 8 hours so im going to sleep, cheers again guys, keep it coming, i will be able to have a proper look tomorrow after uni..
    Stomps
    i'm on adelaide time..... it makes me feel dirty
    Doubt its this cause between cylinders gets worse pretty quickly and within a couple of mins (if that) you'll have a full blown rexi.
    As stu said check compression to be sure
    - LeeRoy
    if it was BHG i would sound different out the exhaust and lose power wouldnt it?
    its lost no power and sounds exactly the same, the noise is a faint mechanical noise, like a knock but very faint..
    gonna go chuck it on a hoist now and have a look..
    Mine did similar. turned out the rear subframe was loose of course, the noise didnt sound at all like it was coming from the engine bay
  1. Diff noise
    Last Post: 11-05-2006, 09:14 AM
  2. Injector rail noise on 1UZ.
    By MacroP in forum Tech and Conversions
    Last Post: 06-05-2006, 09:47 PM
  3. SC12 noise.. is it suposed to do this?
    By AE101LEV in forum Tech and Conversions
    Last Post: 25-04-2006, 04:31 PM
  4. 20v Emissions and exhaust noise testing? (NSW)
    By finney in forum Tech and Conversions
    Last Post: 04-02-2006, 10:47 PM
  5. 6M and 7M differences???
    By fatboy13 in forum Tech and Conversions
    Last Post: 10-01-2006, 07:20 PM
