Sounds like lack of ignition. Pop lead #1 off the plug, insert screwdriver, hold the shalf of the screwdriver close to the cam cover (3-4 mm), and turn the key - you should be able to see a spark. No spark is an indicator that something is not right with dizzy, points or coil. If you've got good spark, I'd be checking fuel.
