Results 1 to 6 of 6
Thread: Removing Gt4 celica drive flanges and wheel bearings
    Oct 2009
    Default Removing Gt4 celica drive flanges and wheel bearings
    So I brought a 12T press on saturday and it took me 15mins to break it just wanting to confirm theres nothing different about gt4 hubs
    so theres no seal or circlips holding the hub centre into the bearing and it should just push out correct??
    Default Re: Removing Gt4 celica drive flanges and wheel bearings
    Awesome. Well done
    correct about nothing holding the hub into the inner race.
    But I can't remember if there's anything securing the bearing outer race to the upright or not.
    wa
    there is no clip holding the inner race to the hub, but there is a big circlip securing the outer race to the upright.
    The hubs normally press out of the spindle(upright) without too much trouble, the inner race of the bearing normally tags along with it... I've heard of people having trouble pressing the outer race from the spindle though - as jonathan yee said there is a circlip to remove for that one (behind the seal I think by memory?)
    I am the sun
    Oct 2009
    ive pulled back the rubber seal on both sides and havent found any circlip
    May 2011
    how did you go with these?
    i know front and rear are opposite rears you push out the front of the hub and the fronts you push out the rear, so they go opposite ways its a bit annoying. it take a lot of force to push the stub axles out.
    mine came out with a large crack, thought i cracked the housing but they are just that tight, and rears are tighter than the fronts for some reason.
    1990 ST185 Running stock Gen 3 power, 216awhp at 15psi. 13.6 second down the quarter
  1. removing drive shafts
    By kaino in forum Tech and Conversions
    Last Post: 28-02-2011, 01:43 PM
  2. Removing axle bearings, T-series...HELP
    By newbien in forum Tech and Conversions
    Last Post: 20-04-2009, 03:14 AM
  3. Rear Wheel Bearings
    By tom in forum Tech and Conversions
    Last Post: 11-02-2009, 10:59 PM
  4. Replies: 9
    Last Post: 12-04-2008, 06:59 PM
  5. help please do i need new wheel bearings?
    By hunty in forum Tech and Conversions
    Last Post: 19-06-2006, 03:24 PM
