i once had a tooth off the spider gears come astray and get wedged between the crown and the carrier... such that the pinion contacted the tooth each time it came around... car still drove ok, but the clunking was terrible...Originally Posted by Draven
i would suggest drop it out and see what broke.. if all the teeth are intact, then check bearings for roughness and go from there?
oh and see if you can correlate the speed of the sound with the speed of the wheels (ie one knock per wheel rotation) = crown damage, or 3.?? knocks per wheel revolution is pinion damage....
for bearing damage, they usually spin at half shaft speed, but it depends on what failed.
you could even be scientific about it wheel diameter = X number of turns per minute at 20km/hr.... then pinion = Y number of turns at 20km/hr....
bearings for crown = 0.5X and bearings for pinion = 0.5Y
then measure clunks per minute at same speed....
i would be very interested to see how this goes as i'm probably just talking shit but if it works in practice... it's a good theory
Cya, Stewart
