Results 1 to 3 of 3
Thread: LEEN AZ6(IS200) transmission to Toyota "A" engine adapter
    oregon
    Default LEEN AZ6(IS200) transmission to Toyota "A" engine adapter
    Watch and enjoy :thumbsup:
    LEEN SXE10 AE86 Conversion - YouTube
    Quote Originally Posted by LEEN Gearbox Conversions
    Over the last two weeks we have undertaken the fitting of a complete LEEN Adaptor kit, Gear Lever Kit, Speedometer Unit and Gearbox Bracket to an AE86. We now have our first LEEN 6 Speed AE86 Conversion complete and back in the hands of its owner ! No standard Car but a 182 BHP supercharged excellently modified machine !
    I would particularly like to thank Joe (Joe81) for giving us the opportunity to test the components in his car. Also want to thank Shaft Tec based in Charleville for an excellent job on the driveshaft and also thanks to Brian who worked with me throughout the installation.
    It begins ....
    Remove one T50 gearbox and add a pilot extension ...
    Then take one 6 Speed IS200 gearbox and add a LEEN SXE10 AE86 Adaptor Kit and a LEEN Gear Lever Kit ...
    and you get a LEEN IS200 Gearbox ...
    Install into a willing AE86 ...
    Check the clearance down the passengers side and no modification to the tunnel required !!!
    Verify the location of the Gear Lever Unit, interesting - no modification to the tunnel required ...
    From inside the car ...
    And finally ...
    Finally the most difficult part - giving it back
    Joe is testing the car as of Sunday morning and all is going well.
    The speedometer is over reading, so I'm back checking ratio's and verifing the final drive. At this point if there is any aspects which need re-design I'm happy for them to be highlighted at this early stage. So not a problem !!
    LEEN Gearbox Conversions is not VAT registered, so this basically means where ever you are in the world, these are the prices.
    The minimum LEEN Gearbox Conversion Kit consists of the following:
    SXE10 AE86 Adaptor (Aluminium 6082T6)
    Sealant Plate (Aluminium 6082T6)
    Pilot Bearing Extension (304 Stainless Steel)
    Two Pilot Bearings
    Clutch Disk (Standard or Paddle, 200mm or 212mm)
    Price: €1291.36
    Note: You will have to modify your own release bearing sleeve for the larger diameter input shaft of the IS200 gearbox or else buy the stainless steel replacement I manufacture. Once machined the wall thickness of the portion the release bearing slides on is reduced to 1.9mm. Because of the thin wall thickness I manufactured a stainless steel one; even with the thin 1.9mm wall it is still stronger than an original un-modified unit. Hence it will not fail in service.
    LEEN Release Bearing Sleeve (304 Stainless Steel): €179.20 - HIGHLY recommended
    Gear Lever Kit including modifing your gearbox to accept the parts: €248.00
    Clutch Disk (Standard or Paddle, 200mm or 212mm): €156.80
    Gearbox Bracket(transmission mount): €95.20
    The speedometer unit is not available until I have it sorted. This company offers a solution: Abbott Enterprises - cable x
    I'm currently in talks with this company to supply their product, it's electronic based so it will suit any final drive ratio.
    The plan is to adapt the kit to fit 6 speed gearboxes from the following:
    Mazda Miata / MX-5
    Mazda RX8
    Nissan S15
    So at present the IS200 is the only gearbox that definitely works with the adaptor. I will begin test fitting to the above gearboxes very soon.
    The headache of VAT (Ireland's Value Added Tax) This may sound confusing ...
    I had two options setting up the business, been VAT registered and not been VAT registered.
    Basically if I am VAT registered the VAT I pay on the raw materials I can essentially claim back (making things cheaper for me to buy) but the TAX man must get his VAT somewhere so the customer is charged 21% VAT. That 21% VAT goes straight into the hand of the TAX man. This system involves making TAX returns every two months and associated accountant fees. So more operating costs and thus higher prices. If I was VAT registered people outside Europe would pay no VAT.
    What I done is set up the business as a 'sole trader.' I'm not registered for VAT, and I can't claim back 21% of the value of the raw materials. I pay the full material price. So I pay the 21% VAT myself and this goes to the TAX man. Thus the price I charge is the price with the VAT allready paid by me, I can't take it off the price.
    So the price is the same for anyone anywhere in the world. This is the simplist solution for me at present to manage this business.
    Hope this explains things.
    Thanks, Joe
    LEEN Gearbox Conversions | 6 Speed Gearbox Conversion | AE86 4AGE | LEEN SXE10
    oregon
    Default Re: LEEN AZ6(IS200) transmission to Toyota "A" engine adapter
    Now adapted to fit the Nissan S15 version of the AZ6!!
    Twisted ****** Backyard Mechanic .T.'s Avatar
    fyi if anyone is interested i have a s15 j160 box in melb (missing shifter) that i got as part of a job lot of parts. no idea of the condition/k's etc, other than i know that the motor that was attached to it went into a s14 drift car......
    open to offers on it
    Toby
  1. Getting transmission to engine adapter plate made??
    By Ms55 in forum Tech and Conversions
    Last Post: 06-04-2010, 03:53 PM
