is a faulty AFM signal going to affect spark? not sure how the ecu would determine spark intervals but perhaps under load the AFM isnt reporting a high enuf reading hence the spark isnt increased accordingly giving you what looks to be a spark break down.
if it worked this way then you would not get enough spark for a given load, but as far as the ecu is concerened .. going by the AFM signal it thinks its sparking right.
or everything you swapped has minor faults compounding together to give you your issue.
lets just hope its as easy as it being the AFM.
