Results 1 to 4 of 4
Thread: W58 Speed sensor pinout
    Apr 2011
    Default W58 Speed sensor pinout
    Hi Everyone, I went looking for the pinout for the W58 gearbox speed sensor and found many threads where others were asking the same question, so once I found the answer I thought I'd post a picture for others to find.
    The signal (Output) is a 5V square wave. The sensor seems quite happy to run from 12V so if using a 12V supply the signal becomes a 12V square wave. Hope this helps others. Regards Ivan
    Feb 2012
    Australia
    Default Re: W58 Speed sensor pinout
    Is this so you can run an electronic speedometer?
    NooB 3TGTE swapped RA40
    ✨Rahgo2:Turbo Boogaloo✨
    I've got it on my wiki also
    Oh and the supply voltage is battery voltage (ignition switched), not 5V
    http://wilbo666.pbworks.com/w/page/5...peed%20Sensors
    Wilbo's JZA80
    Wilbo's JZZ12
    Nov 2011
    just remember centre pin is earth 99% of the time on a toyota
    so this leaves u with the 2 outer wires
    one is 12v other is signal
    so u have 50% chance of getting it right
  1. Pinout for rear speed sensor (ABS) on 7M/1JZ/etc.. Toyotas
    By richardjeffries in forum Tech and Conversions
    Last Post: 03-10-2011, 02:42 AM
  2. R154 1jz abs sensor to Soarer speed sensor 2?
    By 1jz_manual_project in forum Tech and Conversions
    Last Post: 10-08-2011, 12:21 AM
  3. 89420-14020 Pressure Sensor pinout/Wiring
    By irishtwincam in forum Tech and Conversions
    Last Post: 04-05-2010, 07:24 AM
  4. need help with speed sensor
    By hogesjzz30 in forum Tech and Conversions
    Last Post: 01-11-2008, 09:12 AM
  5. Speed Sensitive steering and R154 speed sensor questions
    By Bowlsclubboy in forum Tech and Conversions
    Last Post: 23-10-2007, 08:18 PM
