I went searching over the internet to see what actually came in this kit, and was unable to do so.
I thought I would go through and create a list for anyone else searching for it.
I also have some bits that Im not sure what they are.
Part numbers are from Toyodiy, so they may be a little out of date.
Cam Seals x2 - 90311‑38036
Spark Plug Seals x8 - 11193‑15010
Cam Cover Seal x2 - 11213‑50020
Intake Manifold Gasket (Engine) x2 - 17171‑50010
Exhaust Manifold Gasket x2 - 17173‑50020
Head Gasket - 11115‑50020
Head Gasket No2 - 11116‑50010
PCV Valve Grommit - 90480‑18001
Lower Exhaust Gaskets x2 - 90917‑06043
Upper Manifold Gaskets x4 - 17176‑50020
Water Crossover Pipe Gaskets x4 - 16341‑50010
Cam Cover Bolt Washers x16 - 90210‑07001
Valve Stem Seals x32 - 90913-02085
Injector O-rings x8 - 90301‑07001
Injector Rubber Grommit x8 - 90480‑13005
Alu Washers x4 - Fuel related
Alu Washers x2 - Fuel related
Alu Washers x9 - Fuel related
Alu Star Washer x1 - Fule related
Rubber Split Washer (Cam Sensor Rubber) x1 - 90480‑26025
Rubber Square Washer x1 - 11359‑50010
O-ring for Water By-Pass Pipe x1 - 96761‑24019
Oil Cap Seal x1 - 12195‑50010
EGR Gaskets (Not Needed) x2
Misc Plastic Rubbers x heaps. Includes all the rubbers from the plastic surrounds for the engine.
I cant find out what these are for.
They are ~10mm across, steel washer with a rubber centre.
I have 8 of them.
Building on this, 04111-50040 / 04111-50041 includes the following.
Front Main Seal - 90311‑43004
Rear Main Seal - 90311‑95006
Oil Filter Housing Gasket - 15692‑50020
Oil Pickup Gasket - 15147‑50010
Sump Plug Gasket - 90430‑12020
There is a couple of other misc bits that I cant tell what they are from the diagram.
Any suggestions?
Herus
