Results 1 to 11 of 11
Thread: 18RG Solex's - 40mm or 44mm?
    Feb 2012
    Australia
    Default 18RG Solex's - 40mm or 44mm?
    Is there a code somewhere to tell me the size of the Solex's? Or if I'm suppose to measure it, wheres the best spot measure?
    My Daily: NooB's Delivery Vehicle
    My wife's Daily: Series B RA40 Liftback 22RE, power steering, AC. Cushy as.
    Current Project: NooB 3TGTE swap
    Back Burner: 1964 Toyopet ToyoAce, and a Series B TA45 GT coupe
    Too many cars
    Melbourne Victoria
    Default Re: 18RG Solex's - 40mm or 44mm?
    on the side it will say 40phh or 44 phh
    Feb 2012
    Australia
    Is that visible while they are mounted to the engine?
    Too many cars
    Sep 2011
    http://www.rmcarburetors.net/index.htm
    I think this is "Rodger" site. Very helpful guy!
    Melbourne Victoria
    looking at the front they have markings on the right had side just under the fuel line going in on the bottom section
    Feb 2012
    Australia
    Sorry, I can't see markings anywhere on them. I measure the intake on them though, it's 44mm, so are they 44mm solex's than? or do they mark them by something else??
    Too many cars
    Aug 2009
    It is the diameter size of the throttle butterfly. Measure the manifold side and you will be close.
    Rgds, Willofan
    Feb 2012
    Australia
    Cheers, I'll have to take them off then... Was trying to work it out while they were mounted =P
    Too many cars
    Tasmania
    There is also numers stamped on the butterflies which tell you whats what but I cant think what they are.
    Cheers Brett.
    The two most common sizes Mikuni made in the PHH sidedraught range were the 40mm and the 44mm known as PHH40 and PHH44. The 40mm Solex and Mikuni have a throttle plate stamped #165. The 44mm Mikuni has a #175 stamped on the throttle plate. The rare PHH50 Mikuni is still around and is sometimes known as a Type Q, it is stamped with #180 on the throttle plate. Type Q was also made as a 40mm and 44mm.
    Taken from Rodgers Page: http://www.rmcarburetors.net/index.htm
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
    Hi Marcus.
    The Solex Toyota used most commonly on the 18R-G is 40mm in size. It is a 'cold weather' version of Mikuni's PHH40 (Type R). So if you have the Solex with the integral starter/jet cover with the electrical heating connection then you have the Type T and is indeed a 40mm carb.
    If you have earlier solex carbs (type S4 or S5) you can still work out what size you have without removing the carbs. Both S4 and S5 40mm have a sleeve that fits into the main bore to reduce that end of the carb down from 48mm to 44 or so. These sleeves are held in by a set screw and nut like the ones for the venturi. If you have three set screws along the length of each bore (sleeve, inner venturi, outer venturi) then you have PHH40s. Even if the sleeve is missing there will still be a threaded hole in the bore.
    All PHH44s do not use this sleeve and the set screw hole is blank.
    Regards
    Rodger
  1. Will these rams tubes fit on my twin 40mm solex's?
    By poida in forum Tech and Conversions
    Last Post: 12-07-2006, 10:34 PM
  2. 18rg tuners in Melbourne (solex's)
    By filthman in forum Tech and Conversions
    Last Post: 10-03-2006, 08:29 PM
