Results 1 to 10 of 10
Thread: 4age20v bt help please !!!
    Jan 2009
    sydney, n.s.w
    Default 4age20v bt help please !!!
    hi there
    i have a blacktop 20v 6speed in an ae82 but cant find reverse please help!!
    i can find all 6 forward but no back :-(
    Nov 2011
    Default Re: 4age20v bt help please !!!
    What linkages did u use
    Jan 2009
    sydney, n.s.w
    Engine side ae111
    Interior side ae82
    Junior Member Chief Engine Builder wiso's Avatar
    the standard gear selector in the AE82 might not allow enough movement past 1st/2nd position. you might have to modify it. Have you tried moving the cables inside when disconnected from the selector to see if you can get reverse that way? if you can it means you have issues with the selector.
    89' MR2 AW11... His
    00' MR2 ZZW30... Hers
    Administrator Backyard Mechanic
    Jul 2009
    Quite often the selector mech on the box gets bent during transit (if bought outside a halfcut)... and don't give enough reach to select reverse.
    When i did mine i used the ae111 shifter, there is a guide on http://forum.twincam.org.au/topic/21...e92-ae101-etc/ how to make it fit...
    Jan 2009
    sydney, n.s.w
    sweet thanks guys i will give that a shot.
    i got it in a front cut and i only had the cables no shifter.
    Jan 2009
    sydney, n.s.w
    I have looked and tried the mod but no luck. Anyone know where I can find a ae111 shifter box??
    Oct 2009
    Can you select it manually on the box?
    Jan 2009
    sydney, n.s.w
    No I can't. Not sure which location
    Jan 2009
    sydney, n.s.w
    I'm trying right now but can't find it
  1. 4age20v cams
    By sections in forum Tech and Conversions
    Last Post: 07-07-2011, 07:50 AM
