Results 1 to 5 of 5
Thread: KE70 Rear Axle Oil Capacity
    Selangor
    Default KE70 Rear Axle Oil Capacity
    Does anyone know the oil capacity of the
    Corolla KE70's rear axle, or differential ?
    Thanks.
    Default Re: KE70 Rear Axle Oil Capacity
    The owners manual should list it in the specifications section at the back (It will also tell you what type of oil.)
    According to my Redline oil Guide it takes 1litre of 75/90W oil which is what I would have expected.
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
    New Zealand
    My understanding was you fill it on level ground and the filler hole is the level you need to fill to. Last one I did (was a while ago) either 0.9 or 1.2L seems to ring a bell.
    Callum
    Selangor
    Thanks for the info, Toyman and WDE.
    I dont like the term Grease Monkey beige_bandit's Avatar
    A.C.T
    Confirming 1 litre, but type of oil depends on which book you consult penziol says GP90LS
    which is LSD oil, wouldnt hurt to use it but no need!
    Im just a little lost but ill be fine!
    By The Witzl in forum FAQ
  2. Toyota Part Numbers - Toyota PN# for common stuff
    Last Post: 23-05-2011, 10:54 AM
  3. T series rear end diff centre change guide (warning, pics!)
    Last Post: 31-05-2007, 12:57 AM
  4. Your suspension & you...
    Last Post: 23-05-2006, 08:41 AM
  5. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
    Last Post: 08-09-2005, 01:27 PM
